Question about HP PSC 1410v All-in-One Printer
HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
I have HP PSC 1410 ALL in ONE Printer. I am using original HP printer 2 Original catriges but it is always showing me an Error on Printer as Check Printer Cartrige it is continuously indicates with orange light glowing continuously. My printer HP psc 1410 All in one printer. The printer light blinked non stop "check printer Catridge" even I already put the ink into the catridge. Please asisst me.
    Sergeant:
  • 183 Answers
Turn your printer off and turn it back on.
Posted on Feb 08, 2009
SOURCE:
I have a brand new HP PSC 1410 and after having to buy a black ink cartridge my printer still doesn't print in colour. The printer came with a preinstalled colour cartridge.
The product software print setting is probably designated as grayscale. Follow these steps to check this setting:
  1. In the software application you are trying to print from, click File , and then click Print . The Print dialog box opens.
  2. Make sure your printer is selected, then click Preferences . The printer Preferences dialog box opens.
  3. Select the Color tab, then make sure that the Print in grayscale option is not selected.
Step 2: Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  • Open the Printer Toolbox . There are two ways to open it:
    • Open HP Solution Center , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Solution Center method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and click Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge might be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
    Dec 07, 2010 | HP PSC 1410 All-In-One InkJet Printer
    This eror usually mean that the printer cartridge has not been installed correctly. Try re-installing the cartridge. This error can also be generated by a logic fault within the printer.. if this is the case, replace the printer.. trying another new cartridge can be expensive so try and get a second hand cartridge, maybe from a friend and try that one.. Otherwise, replace the printer..
    Oct 27, 2009 | HP PSC 1410 All-In-One InkJet Printer
    HP PSC 1410 All-In-One InkJet Printerred ink problem
    I know this might sound silly but there is pieces of plastic on the bottom of the cartridges that cover the holes to keep them from drying out, make sure they are removed and then reinstall the cartridges and see if that helps.
    Feb 06, 2009 | HP PSC 1410 All-In-One InkJet Printer
    Hp psc 1410 printer error message
    I fixed the problem I was having by re-installing the program, which then told me exactly what the problem was. It was the color cartridge.
    I then put a new cartridge in and it worked!
    Jan 29, 2009 | HP PSC 1410 All-In-One InkJet Printer
    Hi hello
    You must replace both ink cartridges with GENUINE HP ink carts..
    Jan 20, 2009 | HP PSC 1410 All-In-One InkJet Printer
    my printer is
    HP PSC 1410 ALL IN ONE PRINTER
    ERROR MESSAGE
    1. CHECK PRINT CARTRIDGES
    I AM REMOVE THE OLD CARTRIDGES
    THEN NEW ADDED 21,22 CARTRIDGES
    THEN NEXT ERROR MESSAGE
    HOW TO SOLVE THE PROBLEMS
    Jul 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
    HP PSC 1410v All-in-One Printer Logo
    606 people viewed this question
    Clive
    Clive
    Ekse
    Thomas F. Schneider
