Question about Sony RDR-VX555
VHS TO DVD DUB ERROR ON PLAYBACK
I have been trying to dub from VHS to DVD Sony and TDK brand DVD's and I follow the simple1,2,3 steps as far as insert both disks press dub and done. wait for 2 hours and when the tape in done ok all is done. Well the dvd only seems to play in the SONY RDR VX555 from where it was recorded. MY Apple comp doesn't recognize it nor the XBOX 360 or other dvd players we have arond the house. Is there something wrong. Or it it really only going to play in the RDR VX555?
Same problem : follow instructions to the letter to dub VHS to DVD and when I press <----video nothing happens. Following menu instructions to "simple dubbing" doesn't work either.
I thought it had something to do with the copy protect on the VHS tape but it does not seem to make a difference. Tried with and without it. Please someone help this problem is driving me nuts.
  • 9 more comments
  • adrianne66 Feb 08, 2009
    My question was inadvertantly mixed with someone elses question when I posted. The "guru" answered the first question but did not address my question at all.
    I copied fine dozens of miniDVs to DVD on the same system and was able to copy a single 10 minute segment from VHS to DVD. Now nothing. Same DVDs whole time.
    The "one touch" and the "simple dubbing VHS ->DVD" is what I need help with. DVDs are fine.
    Using Sony DVD-R dvds. No problems with these discs. Is the problem in the copy protection of the VHS? I tried with and without copy protect with no result.
    I'm not trying to finalize yet, I'm trying to continue copying additional segments to DVD before finalizing.
    Hi Please read only second quesiton in this post. My question was inadvertantly merged with someone elses. My problem is that I cannot record VHS to DVD using this Sony RDR VX555 machine. Both the "one touch" option and the "simple dubbing" option yield nothing. The VHS tapes I want to copy are not movies, they are personal research tapes with no copy protection.
    I have been using the same DVDs Sony DVD-R for dozens of recordings from miniDV to DVD working fine. Not the discs.
    Please help.
    You don't finalize between segments, only to close the disc. I am trying to record multiple 10 minute segments to a disc. I cannot record.
    Not having a disc finalize problem. ThankS!
    Not trying to copy DVDs. Trying to copy uncopyright protected research materials on VHS to DVD. No copyrighting problems here.
    Please read entire post. I keep getting responses to bits and pieces of post and not the actual problem. Thank you!!
    Not trying to finalize. Trying to record VHS to DVD. Not recording. See post.
    Please help. Read entire post. All "solutions" have been dead ends or not applicable to my problem.
    Cannot record VHS to DVD using non-copyrighted materials, DVDs that work well with this player, and I'm not having a disc finalize issue.
    Thanks, AjKill - I have tried those things. Any more ideas?
  • Michael Masters
    Michael Masters May 11, 2010
    unfortunately, you will only be able to record the copy in the format that is encoded by this machine. this machine only has limited codecs that probably are outdated and can only be played by this machine only.
  • Sony Master
  • 19,396 Answers
The procedure to Dub on this unit is quite simple.
Start unplugging the DVD recorder from power for ten minutes, this should reset general settings.
After plugging back ensure that you can see VHS on screen before dubbing, and use the easy dubbing procedure and a new CD/DVD , just in case.
If still no luck you may need a firmware upgrade. In this case you need to call Sony phone number listed on the owner manual, they will give you instructions to obtain the right upgrade for this model.
Posted on Feb 08, 2009
    Genius:
  • 1,011 Answers
Sir,
This is the problem with not recognizing the file format. The converted file format is .avi so u must convert the file into dvd format to play the files. How to convert this file format will be shown in this link. Try this.....
Link 2
Thanks Good Luck
  • 6,784 Answers
This machine only has a certain type of codec that it uses to make the copy. these codecs are not universal unfortunately. the dvd copies you make form vhs will only use these codecs, therefore, only allowing you to play the copies on a limited number of dvd players.
  • Michael Masters
    Michael Masters Feb 08, 2009
    This type of segmented recording should be done on your computer with roxio software. it great for transferring or, archiving. all you need is to run the VHS player to your video card via RCA input adapter in to the line in section. and you can edit and cut it.
    Genius:
  • 2,035 Answers
The DVD and VIDEO dubbing buttons will be inoperable and the edit mode will be unavailable. Even though you are not recording from an external device, the DVD recorder must be set to record from the LINE 1 IN or LINE 2 IN jacks to dub from a VHS tape onto a DVD. Press the INPUT SELECT button on the remote control to change the input source from DV input mode to one of the line input jacks ...and then try to dub...
Good luck...
    Sergeant:
    Champion:
  • 289 Answers
Hi..make sure that u have recorded in the
format that supports in the dvd player.once
u creare as a data disc it wil not be playable
in the dvd player.It can be operable ony in the
computer.so first make sure that u have recorded
in the correct format such as video.To make it work
in the dvd player it should be recorded in the video
format.
check it out..
rate me..
  • 360 Answers
In order to play the dvd in other units, the disc must be finalized.
  1. using the dvd remote, press dvd
  2. insert the disc to be finalized
  3. press system menu while the recorder is in stop mode (the system menu appears)
  4. select disc setting and press enter (disc setting display appears)
  5. select disc finalize and press enter (the display asks for conformation)
  6. select finalize and press enter (the display asks for conformation again)
  7. select ok and press enter (the recorder starts finalizing the disk)
to turn off the display press system menu
click -->here<-- for the complete user guide for the unit
please take the time to give this solution a Fix Ya rating.
clarkco
  • clarkco2002 Feb 08, 2009
    Attempt using a DVD RW disk when attempting to record several segments to one disk. Do not finalize between segments, ensure that you don't inadvertently record over previous segments once you begin recording...the link in my solution is the user guide in pdf format if you only have the quick start guide, this may help.
    Master:
  • 474 Answers
They do that on purpose so you cant copy copyrighted materials. If they let you do this, DVD sales would plummet even further down hill.
If you want to copy DVD's you have to have decoder software on your P.C. and a DVD burner.
Most likeley the DVD recorder will encode the DVD with its own Encryption so only it will play it.
Your better off connected a DVD player to your coputer and recording it as it plays and then burnig it.
You have to have certain video cards and software for this, if you dont know how then your better off just searching thepiratebay.com
Not that I endorse violating any copyright laws
    Sergeant:
  • 250 Answers
Finalising the dvd is very necessary after recording to make it play.if not finalised the disc wont play.
    President:
  • 2,110 Answers
You left out one step after dubbing. You need to "Finalize" in order to play the DVD in other equipment. See System menue or read the Operating Instructions. It would probably been appropriate for Sony to put a footnote in the dubbing instructions. Oh well.
    Brigadier General:
  • 3,614 Answers
Try using a different kind of disc. copy it on the desired speed
  • 744 Answers
Hi.. its a major problem that the DVD dubbed in a player wont works in system or XBOX.. the entire file format varies and u cannot pla those DVD in ur laptop or desktop... It is compatible only to that particular dvd player and u cant try to play in anyother player...
thank u
  • Prakash Ram
    Prakash Ram Feb 08, 2009
    If you only plan on doing VHS to DVD then you might want to take a look at a digital video stabiiizer the cost is about $20 compared to the sima about $100. You can find it MCM Electronics.com.. Hope this helps.
  • Prakash Ram
    hi...You need the device some times called Video Enhancer (SIMA-1, 2, or -200) to be connected between your VHS output and your DVD Recoredr Input. That would remove the VHS protection and prevented passing on through your DVD Recorder.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
For a newly recorded disc to be playable in another player and not only the one that recorded it, said disc must be "finalized", that is to instruct the recorder that no more files would be added and therefore "close" the recording session.
Said feature/option would be among the MENU/Settings of the recorder.
Would appreciate updates. Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 08, 2009
    Appreciate your update/clarification. Let's start again and to your concern then not being the same problem, ideas that you could try:
    • use other brand of discs;
    • use only -R.
    Pls give the above a try and update.
Recorded a movie on the DVR, played it & recorded it onto a Sony DVD-R with the Sony RDR-VX525, I believe it finalized & did everything it should. However, it won't play. It says disk error. I went...
what happened was that you probably chose a disc speed on the DVD that was too fast or slow for the dvd players that you are putting it in to. Try re recording it but when under the DVD section, on your remote, choose REC Mode till it says SP. That one should work on just about any dvd player. I had the same problem with mine. Here is a step by step instruction on how to dub from VHS to DVD correctly. If you follow all the steps, you should be fine :) http://angrytechblog.com/2011/02/how-to-one-touch-dub-vhs-to-dvd-on-the-sony-rdr-vx525/
Jan 20, 2011 | Sony RDR-VX525 DVD Recorder/VCR
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
Vhs to dvd - "simple dubbing" greyed out, help please thank you!
check your software, what are you using???? Free software is available at Burnworld.com
Mar 06, 2010 | Sony RDR-VX535 Player
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
JVC SR-DVM600 Dubbing from HDD to DVD Problem
Have you tried using a different brand disc. When I first purchased my DVM-600 it would not record on Memorex discs. I purchased TDK -R discs and all is fine. In the old-school analog world, all specific format tapes were computable to all machines. In other words, a VHS tape recorded in your VHS recorder will play back in my machine and every other VHS machine. Because the DVD format has so many formats and standards, compatability issues are quite common.
May 07, 2009 | JVC SR-DVM600
Won't recognize blank DVD+R disc
Try the next disc in the stack, and see if it will recognize the next one. If not, the problem is most likely the recording speed of the +R disc. Before you go changing disc types, however, I would also check the Record Mode you have set for the dub - if the REC Mode is set for XP, try changing the mode to SP and see if you have any luck. If it still won't work, try one of the tested +R discs:
SONY (2.4x, 4x, 8x, 16x)
TDK (4x)
Mitsubishi (4x, 8x)
Ricoh (2x, 4x, 8x)
-Tha Mp3 Doctor
Feb 14, 2009 | Philips DVDR3320 DVD Recorder/VCR
Sounds like the DVD is not finalizing or not doing so properly. Check your setup options...
Mar 30, 2008 | Sony RDR-VX555
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Aug 23, 2007 | Sony RDR-VX555
Open Questions:
See all Sony RDR-VX555 Questions
Sony RDR-VX555 Logo
146 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
