Question about Frigidaire FWS833A Top Load Washer
Fridgaire washer is leaking water about 1/2 gallon of water
I have a Fridgaire washer that loads from the top that is leaking about a 1/2 gallon of water that is coming from underneath and can not determine where it is coming from.
  • dynamicduo Feb 17, 2009
    I have the same problem, but it is not because of the hose. Seems to be coming from the spinner that turns the washer.
I want a nwe frame
Posted on Mar 14, 2009
  • delroy_jones Mar 14, 2009
    i want a new frame
    iwant anew frame to buy.
    President:
  • 1,902 Answers
If you take off the front panel in the VERY back you will see a hose, that hose has seemed to have come disconnected, there is a valve back there that is just slips onto. This will stop your water leak
Posted on Feb 08, 2009
My sister pours a lot of liquid softener into our Kenmore Elite front load dispenser. I said to only use 1/4 cup as recommended. Will using too much fabric softener cause problems?
YES!! This machine uses an average of 14 gallons of water per load as compared to 40 gallons for a top load!! Less water means less detergents!! Excess detergent and softener can create build up withing the machine that will cause unpleasant odors and eventually rear bearing failure.
Jul 03, 2010 | Kenmore Elite 45986 Front Load Washer
Hiw many gallons of water with 2 rinses does a top
Your washer takes 35 gallons to wash and 35 gallons to rinse. Ask me how I know? Well I work on them but last December my washer (which is the same as yours) developed a problem with the cold water inlet valve. My inlaws and daughter and friends all come by at different times to use paws paws washer. They pass 50 laundry mats to come to my house. Just for fun I told my wife to get a 5 gallon bucket and fill the washer up. It takes 7 buckets to fill the washer up and get it to start washing. Later she decided to run a water hose out to the washer and fill it up. Then my mother in law suggested she put the washer on rinse and fill the tub. That told me I had a timer problem. But luckily I have 2 or 3 washers around the house I can get parts off of. So to recap: 70 gallons of water to wash a full load of clothes is what I guesstamate it took. Did that slow down my inlaws? Nope.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2010 | GE WHRE5260E Top Load Washer
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
Water leaks on the floor at random. 1/2 gallon or so. any ideas
The only way you will find the leak is to remove the front panel and watch while it is running.
I could be many things. The pump, the tub seal, the inlet valve, any of the hoses ect...
Jan 11, 2010 | GE Profile WPRE6100G Top Load Washer
WATER USEAGE
Depending on the age and size of your washer-Front loaders cut water use by nearly 40 percent. A typical top-loading washer uses about 40 gallons of water for each full load. In contrast, a full-size horizontal axis clothes washer uses only 20 to 25 gallons. That means that, by purchasing a horizontal axis model, you could save as much as 7,000 gallons of water per year. You also save all the energy you would have used to heat that water, meaning added savings for you and a big boost for the environment. These appliances also use less energy than conventional washers - approximately 50 percent less, according to the Environmental Protection Agency.
Feb 10, 2009 | Kenmore Washing Machines
Water on my floor
Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaks
to jim, you may want to check the water pump closer, sometimes the water pump will leak a little during a cycle and the water will leak somewhere on the floor, not necessarily near the water pump.
to the second post (guest), it sounds like you have a bad water valve. the valve is not closing properly and causing water to leak thru.
Jun 20, 2008 | Kenmore 24032\24036 Top Load Washer
GE WJSR 1070A Leaking
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Jan 24, 2008 | GE WJSR1070A Top Load Washer
5 yr old washer is leaking
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. Catriver..post back.
Sep 19, 2006 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
Frigidaire FWS833A Top Load Washer Logo
185 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
