Question about Apple iBook G4 (Z0AZW13397068) PC Notebook
DVD is stuck on ibook G4
Is there a way for me to remove it myself?
  • 741 Answers
Get a paper clip and straighten it out. There is a very small hole on the side of the DVD player. Stick the paper clip gently inside and it will release the latch. Let me know if you have any questions.
Don't forget to rate this solution with 4 stars before you log out.
Posted on Feb 08, 2009
I can not install viber apple ibook g4.when ever i try to down load i am told the application viber can not supported by this architecture
Hi Christy,
Viber appears to work only with OSx 10.7 and up, which is not supported on an iBook.
When they say "viber can not supported by this architecture", they're referring to the iBook not having an Intel processor like the MacBooks do.
Hope this helps!
Aug 19, 2013 | Apple Ibook G4 14", 1.33...
I cant Play dvds on my ibook g4 notebook
Make sure you have the right software first VLC is good software and will play almost everything.
Does your version iBook even have a DVD optical drive?
Is the optical drive failing?
Feb 03, 2011 | Apple iBook G4 Mac Notebook
When i try to boot my ibook g4 it gets stuck on a blue screen or the mac logo and it brings up a sign saying to shut down or restart.. i do this but it does it all over again..
The sign i believe you are referring to is a Kernel Panic, if it is a gray box that dims the screen. Example: http://www.ourhangout.net/archives/Kernel_Panic-1p0f.png
If this is the case, and you have your Mac OS X install dvd, try to boot off of the disc and use disk utility to repair the hard drive.
Dec 18, 2010 | Apple iBook G4 Mac Notebook
I have a stuck DVD and can't boot my laptop
this drives has special motor inside controled from mac operation system, you find a hole outside nerby from drive button. put a open clip inside push in and normaly open's drive case. Thy this with computer off.If you cant do it, go to the local repair store, to help you.
Nov 22, 2009 | Apple iBook G4 Mac Notebook
Stuck dvd
Where your cd drive is there is a small hole which you can insert a straightened paper clip into and this should eject the dvd. Hope this helps.
Nov 22, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Dvd will not eject from my iBook G4
Hold down the Apple and the E when you restart your computer.
Mar 13, 2009 | Apple iBook G4 Mac Notebook
CD drive + Flash drive not detected
Some of the iBook G4 optical drives are very sensitive. The best way to test if it is still working is to use the System Disks that comes with every Mac.
Regarding the Flash disk, it may be that your iBook is using USB 1.1 protocol, while your Flash is using USB 2.0. You can check what type of USB your iBook has in the System Profiler. If it is 1.1, then you are out of luck. If its USB 2.0, then you have a faulty logic board.
Either way, not good news for you. Sorry.
Mar 10, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
IBook G4 Fan keeps running
next time you experience this, go to utilities.activity monitor..it will show you what program ir running the "hottest:, and the graph will display what is currently going on. you may have something running your not even aware of...
Jan 01, 2009 | Apple iBook G4 Mac Notebook
No luck
Probably the dvd drive is damaged (boot the computer with a bootable cd and see if it works, if not, change the drive), or it might have weak connection in it's slot, remove it and reinsert it in the laptop, see if it works.
Jan 16, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Computers & Internet Logo
209 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
