Question about Janome Memory Craft 4800QD
Raising and Lowering the feed dog on Janome 4900 MC
I have lowered my feed dog on the Janome 4900MC and now I want to raise it back up for normal sewing. I pushed the dog feed switch made to raise it, turn the handwheel towards me and it still will not go up. I have read the instructions and it is still not working. Am I missing a step??
Thanks
  • gsnell8 Apr 17, 2009
    Have the same problem on a brand new (demo) machine. Will try your solution.
  • Anonymous Mar 15, 2014
    Feed dogs
    New Friend:
  • 186 Answers
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
Actually, I just worked it out! How embarassing - I still had my stitch length set to zero. Ooops!
Posted on Jun 18, 2009
  • Arrietty Sep 02, 2012
    You are totally awesome, you've just solved my problem *blushes*
  • Karen Kelly
    Karen Kelly Feb 17, 2013
    mine too how embarrassing lmao
How do I lower the feed dog on my Janome 4618 LE?
Posted on Mar 24, 2010
How to raise and lower feed dog singer 1425n
According to the manual below, your machine is not capable of raising and lowering the feed dogs. Instead, your machine came with a cover plate that slips over the feed dogs to allow darning and free motion quilting.
http://homeappliance.manualsonline.com/manuals/mfg/singer/1425.html
Nov 13, 2017 | Singer Sewing Machines
How to I adjust the feed dog when using the the zig zag feature?
1. The feed dog is adjusted by raising or lowering the length of stitches.
2. The other control that is of concern for zigzag stitches is the width control being raised or lowered.
May 19, 2015 | Sewing Machines
How do I raise or lower the feed dogs
The older machines had the switch directly behind the needle mechanism. Reach behind the machine and see if you can feel it. It should be a slider type of switch. The real old machines did not have the capability of raising and lowering the feed dogs, so an index card was taped over the dogs so that they would not interfere with free motion. Good luck!!
Dec 06, 2013 | Singer Sewing Machines
I have a Janome 900 MC and I am trying to embroider a label and can't get the carriage to move, it just sits there in one place. I have tried lowering the feed dog and was told to raise it back. I have...
when the feed dogs are in the down postion the machine stay in one place
when the feed dogs are in the up positon then the machine will sew
if the machine still doesn't sew when the feed dogs are in the up position the feed dogs need to be checked to see if they need a adjustment or need to be replaced
Oct 14, 2013 | Janome Memory Craft 9000 Computerized...
Error message asking to lower feed dogs before embroidering, feed dogs were lowered
Try raising and lowering the feed dogs a couple times there may be something in there that's tripping the sensor.
Nov 11, 2012 | Janome Memory Craft 10000
I have a brother ps-53 and after fixing an issue with the bobbin thread not raising I am now having an issue with the feed dog. When turning the balance wheel forward (or by using the pedal as if to sew)...
Sounds almost as if the feed dogs are canted or angled instead of being level. That's an adjustment you would need to get into the lower mechanics for. Other than that I can only wish you luck.
Sep 06, 2012 | Sewing Machines
Feed dogs won't raise and lower on my memory craft 9500, how can I fix this problem?
when your machine on your machine movable arm pushing a switch liver which will raise your feed dogs you can do one thing when your arm moves to the normal possision just given your finger to the upside movable are you see one long switch bar is there just push and see machine feed dogs will come out actualy that action to be done by arm only,you call one MC expart to resoved your problem permenetly.
Apr 21, 2012 | Janome Memory Craft 9500 Computerized...
Feed Dogs won't come back up!
Have you tried sewing with the machine after setting feed dogs to up position. You may already realise but it takes a full revolution of the machine to engage and raise the feed dogs after setting the feed lift control to up (the feed dods will drop as soon as you adjust the feed lift control but will not raise until a full revolution of the stitching mechanism).
If you have already tried this unsuccessfully try removing the cover below the feed dogs and spray lubricant on the feed linkages and try freeing them.
Nov 04, 2009 | Janome Sewing Machines
My material gets stuck in
check and see if the feed dogs are above the needle plate when the needle is in the upright position, then check and see if you have tension in the upper and lower tension units, check this by putting the foot down and gently pulling on the upper thread and pull the lower thread up through the plate and see if it pulls easy or hard if hard then it is good one last thing are the feed dogs in the raised position
Oct 17, 2009 | Sewing Machines
Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
2,291 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
