Question about Mitsubishi VS-60805 60" Rear Projection Television
Mistubishi vs-60805 has to little red lines when turned on.
Hi, i just bought this tv. all works great except it now has two red lines about 2 inches long one on top of the other in the middle of the screen. most of the time you can't see it but there are there. i am hoping this is a simple fix i can do myself. any help or suggestions would be great. also i am looking for a copy of the owners manual. if someone has one in pdf or other digital format that would be great. any answers can be posted or sent to jasonrglass@aol.com.
Thanks. Jason
  • 3 more comments
  • jasonrglass Feb 09, 2009
    i am having a hard time getting a picture of the issue. the lines are horizontal abut 2 inches long, and in the exact middle of the screen. they not get worse as the set warms up. they are more pink than red.
  • jasonrglass Feb 10, 2009
    here is a close up on the tv. you can see the little red lines. Any help on what is causing these would be great.
  • jasonrglass Feb 11, 2009
    Thank you for the help. any idea on how much this might run?
  • JEDLIPS May 11, 2010
    if you cant get the lines out with the convergance adjustment.Your red convergance chip is burning up .try to clean the dust off it and through a fan on it if it get worse as the tube warms up if not your better off looking for another set ,the repair job is around 400.00
  • Henry McKelvey
    Henry McKelvey May 11, 2010
    Hello jasonrglass,
    If possible can you please post a picture of this problem? The reason I ask is this can be one of three things, and how the picture looks will narrow the possibilities down.
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
    Genius:
  • 1,139 Answers
Hello jasonrglass,
Having looked at the picture you sent, I agree with JEDLIPS your convergence amplifier if about to go bad. The reason the picture was necessary was to make a visual ID of the problem, TV's are very complex systems and to make snap judgments often leads to a misdiagnosis of the problem. However, since this is a convergence amplifier problem the credit for its diagnosis should go to JEDLIPS. There are many reference about this type of problem, here is one such solution just to get you started, but I would prefer that JEDLIPS gets the credit for diagnosis
Here is some advice I posted sometime ago, it applies in your case:
.This denotes a convergence problem as you surmised. Believe it or not it would be cheaper for you to replace the two convergence amplifiers and the biasing resistors. You would not actually be replacing the convergence board since these devices are usually located on the deflection board in most cases. However in answer to your question, the boards are easily removed, depending on your level of patience (lots of cables to move around), I would also advise you to either mark down all of the connection you will remove, or take pictures of the board and its connectors. If you choose to just replace the Amplifiers and the biasing resistors there is a lot of information on this site on how to do so: This will get you started:
1) Unplug the TV and then get a schematic of the TV I use http://www.servicemanuals.net or http://www.manualsparadise.com
2) On the schematic locate the STK392-xxx series IC packs (usually attached to a large heat sink)
3) determine if the STK392s are 110, 120 or 150.
4) if the STK392-xxx's are 110s replace with 110s (forget that upgrade stuff it is a hit or miss game that I don't believe you want to get into), if they are 120s replace with 120s and so on.
5)Now to replace the STKs: remove the module from the TV and unsolder theold STKs along with the bias resistors, and replace them with the newones (be sure to apply heat sink paste to the STKs when attaching themto the heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do manual adjustment and the auto-convergence test and then things should be back to normal.
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Now if you think you can do this have at it, if not I would suggest that you have it done by a qualified TV technician.
Posted on Feb 10, 2009
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
Mitsubishi VS60805 screen
If I can't get my 60805 working properly again I may soon have one :-)
I'm located in Orange County, CA, so if you're close I may be able to help you out.
Jun 16, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Green color/tint over the display
yea you have to call a tech to make repairs to your tv it is having problem in the color circuit good luck
Apr 08, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
