Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Blurry screen appears as 3d with blue discoloration
  • 25 Answers
Go into the convergance mode and clear it up ,ther is also three knobs behind the press board one will adjust the overall background
color ,thew others focus.
Posted on Feb 08, 2009
Really blurry
Look in main menu for convergence and see if it will adjust--if off either adjustments or a bad chip---picture will look 3d and red or blue outlines around lettering etc.
Oct 22, 2012 | Toshiba 61H70 61" Rear Projection...
Discolorization
Can you elaborate on the color discolorization? Does oit appear as too strong of a certain color or does it appear as multiple images sort of 3D looking?
Jun 17, 2011 | Sony Televison & Video
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My screen is discolored and blurry. Please advise..
Sounds like contaminated fluid. Each of the 3 crt's in your set have coolant to keep them cool. This coolant over time gets contaminated and causes extreme blurry picture. ITs extremely common on the Magnavoxs. Its also a pretty big job. Replacing the fluid isnt too difficult but because the tubes have to be removed it means both physical alignment and electronic alignment will be necessary. Also dont remove the green tube until you have done both the blue and red and aligned them to the green. Then do the green.. I hated doing that job lol.. I dont recommend you trying it and probably wouldnt be cost effective to pay a shop to do it either.. I recommend buying a new set... Sorry
Oct 19, 2010 | Philips Magnavox 9P6034C 60" Rear...
How do you fix a 52" hdtv ready when its in 3D blurry format
This tv doesn't have 3D capabilities - the image appears blurry because both images are displayed on the same screen at the same time. Just don't use the 3D option from the BluRay player, view the movie normally - 2D.
Jun 13, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Gateway monitor pixels discolored on monitor
This happens when you keep a device close to monitor which uses wireless technology or signal(Cell phone, wireless router or modem). Also try to make distance between speakers and monitor, as speakers contains magnets and that causes such issues.
Nov 18, 2009 | Gateway Profile 5.5 Desktop PC w/17"...
Pictureis blurry and bottom of screen is wavey
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Televison & Video
Hitachi lcd projection tv screen discoloration model 50vs69a
probabally a dust spot on the mirror or the lcd mini panels inside the optical engine.
must be dissembeled to clean.
not for the faint of heart.
Jun 13, 2009 | Hitachi 50VS69 50" Projection HDTV
Blue is mis-aligned.
You need to replace the two convergence IC's - part# STK392-040. Also look for burnt/discolored resistors near the IC's
Aug 19, 2007 | Samsung HCL4715W 47" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
209 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
