Question about Toshiba Satellite A100-S8111TD Notebook
Hello i will like to place this order;Toshiba Satellite A100-S8111TD.To my fiance here is the shipping detail;Name; Margarita Aristizabal Address;21 Quintard Terrace Stamford, CT 06902 USA.hope to hear from you soon.
  • 129 Answers
Hi Welcome to Fixya !
Fixya.com is solely for technical support and not for sales and distribution. If you would like to order a Toshiba laptop, It can be done on this website -> http://www.toshibadirect.com/td/b2c/home.to
Thanks for using Fixya.
Rate the solution accordingly !
Posted on Feb 08, 2009
How do i use it
Hello there,
You can find the manual here
http://www.retrevo.com/d/df/document.pdf?doc=fdaba84709ca9582bdc6aa96b17862c8&ts=1306620216195&rk=0.5704119470901787
Sincerelly,
Steve TM
May 28, 2011 | Toshiba Satellite A100-S8111TD Notebook
How do I remove and replace the keyboard on my satelite A 120 laptop. Can I have some instructions please.
Step one: Remove the two screws from the bottom of the computer that are holding down the Toshiba Satellite A100-S8111TD Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Toshiba Satellite A100-S8111TD Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Toshiba Laptop Keyboard.
Final step: To insert the new Toshiba Satellite A100-S8111TD Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Toshiba Satellite A100-S8111TD Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
G33k
May 09, 2011 | Toshiba Satellite A100-S8111TD Notebook
I have problum dvd writer
is the DVD writer the original unit in the notebook ? if not usre, refer to the manual -- if you dont have manual, go here (it will cost a little )
http://user-guides.co.uk/cddownload/Toshiba/ToshibaSatellite/Toshiba-Satellite-Pro-A100-TOSHIBA-Satellite-A100-Satellite-Pro-A100-161676.html
before you format, try replacing the DVD writer another unit similar
buy recovery CDs here
http://restore-disk.com/restoredisks/Toshiba/ToshibaSatellite/Toshiba-Satellite-A100-S8111TD-with-Intel-Celeron-Processors-XP-Driver-421349.html
i would restore the notebook to factory settings -- this is the best option in getting the computer back to the way it worked originally going to the factory settings management portion in the system and or use your recovery CDs to format and re isntall everything
Oct 15, 2010 | Toshiba Satellite A100-S8111TD Notebook
Sg ram wanted for toshiba lap top 256mbs
Here are some links that could help you:
http://www.crucial.com/uk/upgrade/compatible-memory-for/Toshiba/Satellite+A100-S8111TD+(Intel+Core+Solo%2FDuo+Processors)/list.html
http://www.memoryupgrade.pro/toshiba-laptop-notebook-so-dimm-ram-satellite-satellite-a100-s8111td.html
I hope that will help you.
Mar 28, 2010 | Toshiba Satellite A100-S8111TD Notebook
Is it possible to play a recorded dvd on a pc?
Yes it is possible if you have the need dvd software decoder installed. Most pc shipped within the last 3 or so years usually have it installed. Hopes this helps.
C2Solutions
Feb 19, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209157&rpn=PSAA0U&modelFilter=A100-S8111TD&selCategory=3&selFamily=1073768663&selModel=1209157|PSAA0U
copy paste this link to your address bar and u will see the drivers
Dec 09, 2008 | Toshiba Satellite A100-S8111TD Notebook
Driver For Toshiba
Toshiba does not officially release drivers for linux and solaris. However you can extract each device name that you can download individually. Usually most of the linux packages like Ubuntu automatically recognize and install the drivers of Toshiba A100-105 series. for the model specific details to see drivers you can proceed to http://support.toshiba.com
Hope it will help
Good Luck
Jul 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
