Question about Samsung (sw 252 frns) CD-RW Burner
CD-RW drive won't open
I have an old Dell Dimension DIM 2400 that came with a Samsung CD-R/RW-252s. I can't get the drive to open either by pushing the button on the box or buy clicking 'Eject' from Windows Explorer. Sometimes when trying to open it from Windows Explorer, I get this message:
"This software version is already installed on this system. To re-install this software, you must remove it first, and then run Setup again
from the installation media. For information about removing a program, see Windows Help." (There is a CD stuck in the drive.) Then the focus goes to a different drive letter in Windows Explorer.
  • 15,935 Answers
Stick a straight paperclip into the tiny hole in front a few times. This manually rotates the gears and will eject the cd tray.
If it does not still come out because of the jammed CD - you may need to use force!!
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 08, 2009
Especially problematic if the computer is on its side! Stand the computer on its "bottom" so the tray and the disc inside it are horizontal. Then try the paperclip --- use one of those big ones because they are stiffer. You may have to push kind of hard to get the tray to open. Also, make sure the tray is not hanging up on the face of the computer case.
It won't cost much to replace the drive if you can't fix it, and the disc that's stuck in there can always be removed by taking the drive apart (which will almost surely ruin the drive since they're like those boxes packed by robots --- you'll never get all that stuff back in there!)
Good luck.
Posted on May 05, 2010
HL-DT-ST-CD-RW GCE 8483B WON'T BURN cd
What software are you using to burn with? Have you tried other CD's? What are you trying to burn? Is the file/files copyright protected? Will the DCD/CD rom play media? Have you upgraded your OS?
Dec 12, 2012 | Dell Dimension 2400 PC Desktop
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
I cannot play a DVD on my Dimension 2400. I can
Oops... Man sad but True, it isn't a DVD ROM, if it says CD-RW.
Regards,
Waqar.
Aug 17, 2009 | Dell Dimension 2400 PC Desktop
CD Rom Drive opens and closes over and over won't quit
it happens often because of some materials or cd broken pcs try to clean it carefully
Apr 11, 2009 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
CD/DVD-RW Drive
Any DVD Read writer will work
Jan 01, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 2400
Open your dell, remove the cd drive backwards, the cd driver has two green rails where it glides on. Those rails you ned to put back if you replace it with onother driver.
Good luck to you
Dec 18, 2008 | Dell Dimension 2400 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Samsung (sw 252 frns) CD-RW Burner Logo
1,000 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
