Question about Singer Sewing Machines
Bobbin won't thread
I was making a dress the bobbin thread started looping horribly on the bottom so I took the bobbin out to what the problem was I tried to thread the bobbin and the needle won't catch it nor is it spinning
I could not find my machine on the list it's a vintage singer genie
    New Friend:
  • 186 Answers
If the hook is not spinning then it needs a gear job which will cost you anywhere from $150 to $250 depending on who you take it to. This machine has four plastic gears which should all be replaced, don't just replace the one that is stripped as the others will go bad soon since they are the same age.
You may be lucky in that something has only come loose, but if they are the original gears then most likely is that they need to be replaced.
Posted on Feb 08, 2009
Singer 328K is jamming.
Most likely there are jamming threads at bobbin room under the machine stepping pedal, try to dismantle it to get rid of these threads.
Sep 22, 2017 | Singer Sewing Machines
Why stitches on top are great but bottom are loose and loopy?
Check your upper threading. Make sure it's between your tension discs. Remember loops on bottom, something is wrong with upper threading/tension. Loops on top something is wrong in the bobbin area (like the bobbin being in upside down or a loose bobbin tension spring)
start by rethreading the top thread with the presser foot UP.
Jun 11, 2014 | Singer Quantum 9910 Computerized Sewing...
I am just making a regular straight stitch and the thread on the back of the fabric is looping ALOT! what am I doing wrong
change the needle
make sure the bobbin is inserted correctly into the bobbin case
make sure the top thread has not come off the thread take up lever
also try adjusting the top thread tension
Sep 01, 2012 | Singer CE-100 Futura Computerized Sewing...
Thread getting caught in bobbin area
If you are seeing the needle thread in loops and birdnests then its the needle thread you need to check. The main reason is it is not threaded through the takeup spring(the one that moves) This action is critical as it is how the thread is pulled up tight. Also make sure the needle thread is between the discs and that it has sufficient tension that you do not see it on the bottom of the material. Try this: Use two different color threads for needle and bobbin. If you see the needle color on the bottom then the needle thread is not tight enough (or in 5% of the cases the bobbin is too tight or hung up). Let me know how it does. Jay
May 28, 2009 | Sewing Machines
Thread getting caught in machine underneath
Try rethreading the top of the machine making sure you get it thru the tension wheel correctly.. General rule of thumb.
If it loops on the bottom, the problem in on the top.. Loops on the top, problem is with the bobbin.
Apr 14, 2009 | Sewing Machines
Pfaff Expression 3.0 works great in the shop, but when I get it home the bobbin thread doesn't engage with the needle thread. The needle thread ends up making large irregular loops on the bottom of the...
pfaff expression 2.0 works the same. I spend lots of hours with the thread tension and it don;t give me a good stitch. the needle threed ends up making large irregular loops .
Apr 12, 2009 | White Sewing 1521
Looped bottom thread
Sorry I missed your problem, I have just signed up on here to help with problems like yours.
Thread looping underneath the cloth is a bobbin tension problem.
Folks in general are not aware that in addition to the top tension being set correctly so must the bobbin tension.
It is impossible to explain how to do this you need to be shown. However it should be explained how to do it in your manual.
Jan 29, 2008 | Janome Mini Compact
Bobbin Problem
there is a thread tenchener screw that the repair center has to ajust so it will have the tenchen Dan
Apr 02, 2007 | Brother SE-270D Computerized Sewing...
Tons of loops on bottom
Check your threading.
Berhaps your thread is not between the discs.
Mar 09, 2007 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
179 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
