Question about RCA Televison & Video
Tv's green light comes on then off three times
I brought a R52WH74 2yrs ago, I have already replaced one fuse FL231. Now the TV tries to come on( still just the green light on, no picture) but now I have the thin color bars horizontally in the center of the screen, now what?. TV tries to reset three times and then goes off. When you first turn the TV on, it is fine and then it looks like 3D, it will turn on and off 3 times and then when it comes back on it looks awful. I just got this TV last January 28th and now the warranty is out. Hope someone has a solution. My TV is RCA model R52WH74.
  • RCA Master
  • 5,138 Answers
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Posted on Feb 08, 2009
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
Tv started ghosting in red green and blue
The tv is have a problems call convergence,it dead.U have all the tools like soldering iron,solder and desoldering pump.Know basic soldering?The convergence fuses FL231 three of them on the right side of FBT,a big block of plastic of a flyback transformer.Resoder the FBT,replaced the convergence fuse FL231 in the middle.The Ebay.com sell the convergence fuse.
Aug 25, 2010 | RCA HD52W59 HDTV Projection Television
Tv just looks like i folded picture need help on configurance set
The tv have a problems known as a convergence problems,it dead.U have tools,soldering iron,solders.U know how to do solders?Try Ebay.com to buy a convergence Fuse(FL231).The big block of plastic call the FBT.Resolder the FBT.The 3 three fuses caps on (FL231) beside it.The covergence fuse cap in middle is dead,replaced the covergence fuse cap in the middle will solved ur convergence problems.
Jul 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cant find convergence in setup
There are three small rectangles sqaure boxes cap fuses parts(FL231) the one in the middle is dead.Replaced the one in the middle located right side near of the big black block of plastic call FBT.U know how to do soldering and have the equipments?Try website like Ebay.com to the cap fuse part(FL231) fuse.After the cap fuse(FL231) is replaced the Convergence well return,ur tv back to normal.
May 28, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
With TV OFF Press and hold vol- and ch- at same time untill tv comes back on release you should now be in Service Menu.
Feb 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Same as everyone green light comes on for a couple of seconds than back off!!!
ok, the problem with short detect....
unsolder all convergance ic's and try to turn it on.
does it come on?
if no, check all diods in the power suppy area.
check h-output
does it come on?
also might have a vertical ic.
mmm, check all fuses including the solder in pico fuses.
beleave they are sold green color.
when i get one that comes in they have 1 or 2 blowed pico fuses and that means convergance ics need replaced along with fuses.
good luck!!
Apr 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
269 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
