Question about Epson Perfection 3490 PHOTO Flatbed Scanner
Scanner quit Version:0.9 StartHTML:-1 EndHTML:-1 StartFragment:0000000111 EndFragment:0000001393 My scanning quit working very little use. Reinstall driver , software many times without success. Just noticed that as soon as I plug it the right on button comes on always and do not shuts off ever even if you press it to close it.
  • Gilles Boudreau Feb 08, 2009
    garantee over is there any place to find parts for it
  • 537 Answers
Is the scanner still under warranty? If so, then see if you can get complementary service for the unit. Otherwise, it might be time to junk it.
Posted on Feb 08, 2009
Life fitness ticking from foot pedal
1Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Version:1.0 StartHTML:0000000168 EndHTML:0000002129 StartFragment:0000000818 EndFragment:0000002112
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
God bless you
Mar 31, 2013 | Life Fitness X8 Advanced Elliptical Cross...
Treadmill E1 Error
Version:1.0 StartHTML:0000000168 EndHTML:0000001348 StartFragment:0000000468 EndFragment:0000001331
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it.
see the diagram attached. and follow steps.
God bless you
Version:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 29, 2013 | Exercise & Fitness
E07 keeps coming up on my display for my carl lewis tredmill does anybody know what the problem is
follow the 2 options and fix it. However RUN the software calibration for easy troubleshooting and fix it. God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000006037 StartFragment:0000000468 EndFragment:0000006020
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Mar 27, 2013 | Exercise & Fitness
Error 7 for lifergear 97688a
follow thw 2 alternatives for fix it. see the diagram attached.God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000005982 StartFragment:0000000468 EndFragment:0000005965
ERROR CODE # 7
2)Alternative:
My bike reads E1 when I plug it in
Version:1.0 StartHTML:0000000168 EndHTML:0000001293 StartFragment:0000000468 EndFragment:0000001276
test the speed sensor for open or faulty. clean it, and tight the connector very well. see the diagram attached. However RUN the software calibration for easy fix it.
God bless you
Mar 21, 2013 | Schwinn 220 Recumbent Bike
My kodak easyshare cx7430 camera has pink in my pictures, how do I get that out?
follow this steps and fix it. God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000003236 StartFragment:0000000502 EndFragment:0000003219
1. The batteries may need replacement. Somedigital cameras continue to function when their battery power is low, but produce grainy photos with incorrect coloration. Make sure you aren't using Ni-Cd rechargeable batteries, which are generally not recommended for cameras.
2. For the best picture quality, make sure the camera is set to its highest resolution. This may have been adjusted by accident. The process for doing this varies greatly among different digital cameras. Keep in mind that fewer photos will fit in the camera's memory and it will probably take longer to transfer them to the computer, at a higher resolution.
3. Digital
photography tends to be more prone to blurring (caused by slight movement of the camera while the photo is taken) than 35mm film, especially with very small or lightweight digital cameras. To remedy this, try using a tripod and/or the camera's timer, if it has one. Adjust the camera's shutter speed if possible.
4. If colors are too pale, using an image editing/viewing program (such as PictureWorks MediaCenter) to increase the Saturation level may be helpful. If the camera has produced colors which are entirely wrong (everything is in shades of black and purple, for example), you can turn the saturation all the way down so that it becomes a black & white photo.
5. The lens may need cleaning. Make sure you use a cleaning material which will not scratch the lens. If possible, refer to its manual for specific cleaning instructions
Jan 30, 2013 | Kodak EasyShare CX7430 Digital Camera
Lifefitness cross trainer has little resistance please help?
follow this step and fix it. God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000001997 StartFragment:0000000515 EndFragment:0000001980
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridgeicon1.png magnet. If not, the magnets have de-magnetized and need to be replaced.Test with the magnet from a refrigerator, If the magnet attract and repulse, is o.k If not replace the magnet.
Jan 10, 2013 | Tunturi Exercise & Fitness
Po183 nissan murano 2004
Version:0.9 StartHtml: 105 EndHtml: 1264 StartFragment: 334 EndFragment: 1232 The fuel tank temperature sensor is used to detect the fuel temperature inside the fuel tank. The sensor modifies a voltage signal from the ECM. The modified signal returns to the ECM as the fuel temperature input. The sensor uses a thermistor which is sensitive to the change in temperature. The electrical resistance of the thermistor decreases as temperature increases.
Apr 18, 2012 | 2004 Nissan Murano
The Whisperkool 4200 unit is no longer cooling the wine room. The digital display is jumbled and will not reset when unplugged. The fan runs constantly but the wine room is only be cooled to 64 degrees. I...
Version:1.0 StartHTML:0000000149 EndHTML:0000001329 StartFragment:0000000199 EndFragment:0000001295 StartSelection:0000000199 EndSelection:0000001295 All WhisperKOOL units come with a 2 year parts and labor warranty with a 5 year warranty on the compressor. During the warranty period, if the unit fails a replacement unit is sent at no cost to you. If your unit fails after this period we offer a Consumer Care Program to give the customer a chance to get a new unit at a deep discount. In many cases, the failing unit has been misapplied and the correct unit for the installation is sought after during the replacement process. Our customer service department is trained extensively, with live customer service representation with a streamlined process for not only helping with the products, but also assisting in identifying any limitations to the installation or ventilation of the cooling unit.
If a repairing the unit is the decided route, call WhisperKOOL directly at 1-800-343-9463 and parts can be ordered depending on availability. A knowledgeable HVAC Professional should perform any repairs due to the refrigeration system.
Jun 30, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
"The Scanner has reported a hardware error..."
Version:1.0 StartHTML:0000000105 EndHTML:0000008195 StartFragment:0000002796 EndFragment:0000008159 Normal 0 0 1 464 2648 22 5 3251 11.0 0 21 0 0 I brought a coolscan 9000 the last month without the film holders, software etc just the scanner. A friend of mine sold me it for a good price. I run Leopard in a Powerbook G4 15” 1.2 ghz 2 Gigas ram. I installed the Nikon scan 4 and when I open it the scanner report an error: The Scanner has reported a hardware error... every time that I run the program this message appears. I thought that this was because I hadn’t got the film holders. When the film holders arrive from USA the same problem appears : The Scanner has reported a hardware error... Them I tried Silverfast Software. In this case the scanner report another error: there are not film holder ( or something like that). I uninstalled Nikon Software with the same utility to install it. Reinstall the Software and the same ****** problem. When I switch on the scanner a loud noise came from inside, after this the blinking light stopped and nothing happen ( no calibration, no light inside, nothing). Just one thing. The Scanner has reported a hardware error...
I checked on internet and the solution of switch it of and on doesn’t work. CALL TO THE NIKON SERVICE that’s was my only solution.
Of course I didn’t . The price of the scanner was 300 Pounds.
SO I OPENED IT.
I REMOVED THE SCREWS FROM THE BACKSIDE AND FROM THE BOTTOM OF THE SCANNER. I TOOK THE METALLIC CASE OF: PICTURE 1. After a while looking everything without touch I’m start to check for the connection cables one by one, WHEN DISCOVER THAT ONE CABLE PLUG THAT GOES FROM THE SCANNER TO THE FIREWARE BOARD WAS DESCONECTED…. PICTURE 2 Maybe on the shipping this plug looses his place. SO I SWITCH ON THE SCANNER AND THE PROBLEM DOESN’T APPEAR. Now the problem was that the film holder wasn’t recognising from the scanner. So I followed the steps that most frequently indicate on the web:
1-Close the scan program –
2-Turn off and unplug the scanner
3-Plug the LS9000 back in and turn it on
4-Reopen the scan program
The scanner worked. When I switch on the scanner take a minute or so to calibrate and determinate the film holder. Them I open the Nikon Scan 4 and every looked nice. I could scan my first negative ALELUYAAAAA. So I close everything without the screws so I put the scanner vertical to put back the metal case ones I finished I turned on the scanner and the Nikon program. For my surprise the same ******* error I couldn’t believe it.
I opened it again and I found the cause of the problem . BECAUSE THE SCANNER WAS ON VERTICAL BEFORE, THE METALLIC GUIDE THAT CONNECT WITH THE SERVO WAS MOVED (Move the scanner from one place to another may cause this issue) So with my finger I putted it in the same place. THE SCANNER WORK’S.
After this the only problem was a big loud gnashing and grinding noise that I sorted with CELOTAPE BETWEEN THE TWO PIECES THAT WAS SEPARATED BEFORE.
PICTURE 3
Now the scanner work fine. Sorry for my **** English and I hope that someone can find useful this information.
Feb 27, 2008 | Nikon CoolScan V ED Film Scanner
Epson Perfection 3490 PHOTO Flatbed Scanner Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
