Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Shattered glass window on oven door
The glass just shattered during a clean cycle tonight. What to do?
Are there service bulletins on this problem?
Can we order a new door?
It's a 2001 Kitchen Aid built in electric convection oven.
I can't open the door yet because it's too hot to see the model number
But it's in the family of KEMC307 and 308
KEMC377 and 378
YKEM307 and 308
  • Anonymous Apr 06, 2009
    The first time I used the cleaning cycle of my KITCHEN AID oven (Model KDRP 467KSS07), the inner glass in the oven door shattered.
    I called the Kitchen Aid 800# inquiring as to what may have caused this or how to prevent this from happening again. Was told they had never heard of this happening before.
    Any info. on this would be helpful.
    homegarrison@aol.com
  • Anonymous Apr 25, 2009
    Same thing has happened to me (first time using the self-clean feature). KitchenAid says it's not under warranty!
Can I install a cooker by a window
Posted on Feb 08, 2009
Broken glass after cleaning cycle......is the oven wstill safe to use??
I would recommend that you do NOT use the oven until you get the glass replaced, remember that very high temperatures are involved and the other glass could easily shatter with the heat.
Dec 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven glass door shattered on the inside during self clean mode
The glass is replaceable. You need to get the exact glass replacement kit from the manufacturer. I had to have mine replaced about a year ago due to condensation between the 2 glass panels and was able to get the replacement for $0.00.
Suggest to Siemens that the glass on yours should not have shattered and therefore was probably defective and you may luck out and get the glass for free. It's worth a try.
Mar 18, 2010 | Siemens Ovens
My oven inside glass door exploded tonight while
Very rare, in 35 years I replace maybe 2 to 5 a year out of 1500 to 2000 repairs a year on all major appliances. Make sure you replace it with the exact glass from the manufacturer, usuing your model number. Do not replace with glass from a glass shop.
Jan 29, 2010 | Ovens
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Whirlpool oven door
the rep is right as of yet there is no recalls on this problem and yes they are tempered but in my many travels I hve only seen two do this once you have the glass replaced this will take care of the problem also if you use a oven cleaner that is not made for self cleaning ovens and get even a drop on the glass it will shatter
Oct 19, 2008 | Whirlpool RBS245PD Electric Single Oven
Outer Glass Microwave window shattered after baking popcorn
doubt anything to do with popcorn. glass like that does sometimes shatter probably a stress fracture. quite often happens with oven doors as well
Apr 19, 2007 | KitchenAid KEHC379JSS Electric Double Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
808 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
