Question about Dell Inspiron 1501 Notebook
Inspiron 1501 ac adapter problems
I just got a new ac adapter for my inspiron (from dell) and when I plug it into the eletrical outlet the green light on the brickk stays on for about 2 seconds. Then nothing and when I plug it into the computer still nothing. I can charge my computer with my sons ac adapter from his 1525. Any suggestions?
  • immalik726 Feb 08, 2009
    my original charger isnt working,it wont charge the computer and the light green is not on?what shall i do?replace the whole computer or just buy the charger?how much does those run for and where can i find it?
  • reddcard Feb 19, 2009
    I have the exact same problem when the adapter is plugged into the wall the green led is lit. When i plug it into the computer it immediatley goes out. I have tried it with my old adapter and a new one from Dell. Should the computer work with the adapter when the battery is out?
    President:
  • 2,692 Answers
Send it back and get another . It is obviously defective if the other works on your computer.
Posted on Feb 08, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Dell inspiron 1501 cannot indentify ac adapter
try this first. drain the flea power. remove batter and ac adapter. press and hold on the power button for 10 seconds. plug back ac adapter and battery. go online to http:support.dell.com then download the latest bios update.
once you reach the dell support site select on support for home users. then drivers and downloads. enter the service tag.
when the list of drivers and updates are listed make sure you selected the correct operating system. look for the BIOS then download it via browser. (do not download the manager)
after the download run or install the update.
If all fails. try a diff ac adapter if same problem message appears then replace the motherboard. else replace ac adapter.
Mar 30, 2010 | Dell Inspiron 1501 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Dell 1501 Error- AC Adapter is not recognized
myabe the battery is faulty have you tried replacing it?
Sep 07, 2009 | Dell Inspiron 1501 Notebook
On the issue with th ebattery on the 1521 inspiron. Took battery out and plugged in still will not power up. Could it be the adapter as well?
On the ac adaptor, look for a green light that will turn on when you plug it into the wall outlet, if its on that means the ac adapter working. If you get a green light on the ac adapter but then the green light goes away when you plug it into the laptop then that means the laptop has a bad motherboard.
If you plug the ac adapter into a wall outlet and get no green light then that means the ac adapter is bad and you would need to get another one.
Jun 21, 2009 | Dell Inspiron E1705 Notebook
Dell Inspiron 1501 will not boot with battery or adapter
Take the battery out and try with AC only, if no change, then you will likely need a motherboard replacement
Jun 04, 2009 | Dell Inspiron 1501 PC Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron b130
check if the ac adapter or charger has a green light on it. if not, replace the charger. for dell chargers, it should have a green light to indicate that the charger is getting power from the wall outlet. if the ac adapter is good, then you might need to replace the mother board as the ac port is integrated.
hope this resolves your problem.
Nov 12, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 1501 Notebook Logo
103 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
