Question about Sony KV-36FS16 36" TV
5 blink error code on a Sony Trinitron KV-36FS16
I have a Sony Trinitron KV-36FS16 and it cuts off by itself many times a day. Sometimes it just shuts off and sometimes the screen goes blue with white horizontal line before it shuts off. Also, when it starts acting up the picture dims on and off almost like it has an intermitten color. When this starts happening, the standby light gives a five blink error code. Any help on this would be greatly appriciated.
Thanks,
Jason
  • 116 Answers
SOURCE: Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
Posted on Mar 01, 2008
  • 9 Answers
SOURCE: RE: Flashing "Standby" light
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at eclipsedave@yahoo.com if you run into difficulties.
-Dave
Posted on May 12, 2008
ikecur
  • 52 Answers
SOURCE: Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Posted on Oct 30, 2008
  • 106 Answers
SOURCE: Sony FD Trinitron WEGA KV-34HS510 34
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
Posted on Mar 24, 2009
micromaster
  • 3614 Answers
SOURCE: the standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Posted on May 30, 2009
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony kv34hs420 shut off itself
Hi:
If you count the number of error blinks when it shuts this will let you know the error code you are having. If the red led blinks say 6 to 7 times after shutdown then pauses and does it all over again there is a problem with the deflection board or D Boardas sony calls it, It is usually related to the two Power supply regulators IC's on the D-board.
Nov 09, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony wega
Would you like to tell me about stand-by light condition when TV goes to Off/ shut-down? How many times this light blinks?
Actually light-blink gives feeback about problem area. You can say it Error Code.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-36FS16 36" TV Logo
419 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
