Question about Hitachi 50SBX78B 50" Rear Projection Television
Hitachi 50SBX78B Horizontal lines and bow
Hi This has a line clear picture on the top 80% of the screen But the bottom has slight red shadow (convergence?) also has a hourglass effect starting ,,now the Lines,,they go across the whole screen about 1/4 way down many lines about 4-5 inch wide distorts picture right there . the rest is a perfect picture ,, this set has this digital Convergence Magic button , does this system clear up Bad STK IC's this well while causing the lines ?
  • johnmk13 Feb 08, 2009
    I made a slight adjustment to Horizontal lines are gone hit the service button grid appers I see the red looks good ,, green and Blue are way off in top left and bottom left ,, so Looks like Convergence IC's must be the ticket ,, any one know which ones are used in this set ? looks very time consuming to get at them in this set ,, Huge board , heat sink clamped totally around them no #'s visable
  • johnmk13 Feb 12, 2009
    OK I Put the IC's in ,, Resistors didn't show any signs of heat, burn ,, the blue is still messed up,, looks like it's over sized flashing and blurry ,, while in magic focus the text is stretched off the screen ,, only the blue ,, as I wait for it to discharge before I go back and remove the board again for a better look at my work, is there something in general I might have over looked ?
    Scholar:
  • 150 Answers
John, Hitachi site is down at the moment, if you remove the clips on the front of the IC`s you will see the numbers of the convergence ic`s, and yes they are a pain to get out, they are probably stk 392-110`s if they are the originals, you`ll have to un-solder 36 pins total to get them out, check for burnt resistors in the general area of the ic`s and replace any that are burnt before turning the set on,be sure to order a tube of "heat sink compound" to apply to the back of the new IC`s, once on the set will probably still look poor, this is normal, run the set for minimum of 15 minutes then push the " magic focus button " inside the front door panel, after it has finished running magic focus it should look great, video-tek
Posted on Feb 09, 2009
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
I have a Hitachi 46F500 tv and the red crt bowed
I just had the convergence replaced and have a great picture
Aug 16, 2009 | Hitachi 46F500 46" Rear Projection...
Picture at top of screen, bottom half is black...middle of screen has horizontal red, green line which is slightly bowed upward. model # is GE 46gw948
Call a good TV Tech and tell him the Convergence Amp IC's need to be replaced. Should not cost over $325.
Jul 29, 2009 | Televison & Video
Red bowed horizontal lines
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2009 | Hitachi 43GX01B 43" Rear Projection...
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red bow on top and bottom of 61dx01b
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 20, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Red Lines On Screen of Hitachi 43FDX01B
can we see a picture of that?? I dont understand whatyour saying about the lines.. Are they differant colors or all red and do they make the pic bow?? does the pic look or have a reddish tinge to it?? is ther too much red in the picture??? Please let us know or let us see??
Apr 11, 2006 | Hitachi THE SOLUTION 3511 Projector, Mount...
Televison & Video Logo
148 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
