Question about Uniden Cordless Phone
My second handset is in its base and it says it is searching. It has been working fine until this afternoon.
  • 1,800 Answers
Check the previous procedure then try a restore settings in the menu.
Posted on Feb 08, 2009
  • Uniden Master
  • 19,396 Answers
Unplug all cables , wait ten minutes and reconnect, this will reset the unit.
  • 6,784 Answers
Hi there, you will need to unplug the unit and let stand for about 5 min. take out the batteries in the handset as well. after 5 min, reload the batteries and plug in the main unit. this will reset the entire internal program. this should fix the problem.
  • Michael Masters
    Michael Masters Feb 08, 2009
    One more thing, if your phone has the same issues after this reset. you may have to send it in for a repair.
Why does screen indicate "searching"?
The handset cannot communicate with its base.
When the handset cannot establish its secure (encrypted) radio
link with the base it is 'paired with' or 'registered' to, it will first
say "Connecting....", then it will display "Out of Range or No
Power at Base", then it settles at the infamous "Searching..."
display.
Although rare, the registration between base and handset can
become corrupted and lost so that we must de-register and
then re-register the pair.
First, ensure that power is 'on' at the base (a more common cause)
and the cradle will charge the handset, etc.
Second, be sure the handset battery is well charged as a weak battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
after ~30 seconds the handset should display
"Handset #" and be good to go...
or it will display "Registration Failed"
Mar 20, 2016 | Uniden DECT 6.0 Cordless Phone
There is a message "Searching" on the phone, How do I get it back to working.
You might try to de-register the handset and re-register
it to the base. Be sure the handset's battery is well
charged, a weak battery can impede the registration.
( I ) To de-register the errant handset:
1. Press and hold the [END] and [ # ] keys at the same time until the screen displays
2. press [select]
3. scroll to "Base Unavailable"
4. press [select]
5. display says "Not Registered"
( II ) To register the handset to the base:
1. open the base display's [menu]
2. scroll to "Register Accy."
3. press [select]
4. on the handset, press and hold [ # ] until
the handset display says "Registering"
5. In ~30 seconds, handset display will say
"Registration Complete" or
"Registration Failed".
This is described on page 22 of the manual.
A free copy of the User's Manual can be obtained
at www.manualslib.com .
Jan 15, 2016 | Uniden D16883 Phone
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and
must be de-registered and then re-registered.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Oct 17, 2014 | AT&T El52300 Cordless Phone
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
Uniden phone stuck at searching, not getting a dial tone
One thing to try is deregestering your phone and registering it with the base again.
Hole the # and 'End' key on the handset until the next menu appears (about 5 seconds). Select deregister phone (use the 'Menu' button). Do it again, but select "base unavailable". After that, set them in the base (not the handset charger) and they should register with the base.
This works on most Uniden model phones.
Jan 29, 2013 | Uniden DECT 6.0 Cordless Telephone...
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Okay I have an at&t brand CL82209. The one with the big main base and the little other one. So the main base works and its fine and all but we need the second one for our other room in the office and...
There is a simple FIX here:
From the "Connecting...." handset, type *331734# then hit MENU button.
Boom..... handset should now read "NOT REGISTERED"
Now you're ready to follow the manual directions:
  • Place handset on main base
  • Hold "Handset Locator" button until red light solid
  • Remove handset and then place back on base
  • Handset should now be registered
You're done!
Jun 12, 2010 | AT&T CL82209 Cordless Phone
How tomake outgoing calls with my american telecom digital cordless phone model#ra23634H
Thuis was hard to find but it worked for my ra2364hh's
note the phone stopped working in "tone dial" after 2 months and now functions with "pulse dial" only.....
Registration The handset and base will be pre-registered with a digital security code identification, which is stored in the phone’s memory, so that your phone will be ready to work right out of the box. However, your phone also has a procedure to allow you to re-register in case the link is lost accidentally. Enter menu, press the key - Select REGISTER and confirm PIN CODE will be displayed, enter the PIN code (the default value is 0000) and confirm. SEARCHING will be displayed while your handset is in registration mode Press and hold the Page key for 3 seconds on the base until the “In use” LED is ON, putting the base in registration mode SUCCESS will be displayed. This means the handset has located the base, and will get a handset number from the base that displays after the handset name for internal calling. If the handset does not locate the base, FAILED will be displayed and it will return to the non-located display mode that displays BS SEARCH with the antenna icon flash. Try again and check that you are not in an environment with interference. Note: Your base can register up to four handsets. If you have more than one handset, repeat the above steps to register each new handset.
TESTED IT 2 minutes ago and it WORKS.....
tony
Feb 23, 2009 | Lands Phones
My landline phone dialtone I get a beep,beep,beep before dialtone
I had the same problem. To fix it, I unplugged the base from the wall, and the battery from the handset, left it all unplugged for 30 seconds, and then replugged everything back in. It works fine now.
Jan 06, 2009 | AT&T 650530003417 Cordless Phone
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Uniden Cordless Phone Logo
16 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
