Question about Sony Audio Players & Recorders
Sony STR-D460Z receiver
Receiver will power up fine then goes in to protect mode. I turned my STR-D460Z sony reciever on with my Samsung TV, Sony Surround Sound Speakers, and Samsung DVD player hooked up to it and it worked for over a year but it didn't work this time. The manuel doesn't help, all it says is to eliminate the short then turn it on but it doesn't tell us anything els. I unplugged everything from it and unploughed it then plugged it in and turned it on but it just came on and flashed "protection". We pulled the cover off and ran the cleaner through it gently, put it back together, turned it on with nothing plugged into it and it still flashed and flashes "protection".
  • Scott Frye
    Scott Frye May 11, 2010
    HI...
    Is there a separate switch on front for turning ON/OFF the speakers?
    Are ALL the speakers connected when you try to power up?
    If so...it very well might be a blown amplifier output.
    Genius:
  • Sony Master
  • 1,689 Answers
A common cause are failures in the amplifier output stage, the drivers, and some of the support components. You will have to send the unit out for service.
Jerry G.
Posted on Feb 09, 2009
The receiver will be on for a while 5mins.or so, then it will make this loud sound as it goes into protector mode...what is this and how do I fix this. I have it connected to the TV, DVD Player, CD, VHS...
you have speaker wires that are shorting out. unhook all the wires and ohm them out. Find out which one is shorting. I've had this problem before. It's fine until you turn it up, Then the receiver turns off and goes into protect mode. It's just a short in the wiring,.
Dec 08, 2010 | Sony STR-DE835 Receiver
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
Reciever on protect mode
Hold in power button until unit "clicks." Takes about 20 seconds.
Jun 18, 2009 | Sony STR-DE325 Receiver
I have had this problem several times with Sony receivers in the past. The issue may be frustrating but these receivers are idiot proof. It is doing you a favor by tripping and not setting your house on fire as well.
Explanation:
Many things like improper wire crossing or touching due to too much of the insulation stripped off can cause this. Thunder storms and power surges as well have been known do this to Sony receivers.
Solution:
Unplug the unit and remove the cover. Look for any blown fuses as sometimes this is the problem. Take the fuse to a Radioshack to find new ones. However, it is likely you will need to take it in for repairs. This usually costs around $100. Find a local electronics repair shop in your area ( "TV Reapir in the yellow pages") or call Sony to send it to them.
I hope the latter works.
Mar 31, 2009 | Sony STR-DE475 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
HI, I have a sony v555es amp and it gives me the following error message "protector OPT.....please power off"
You might be trying to push it too hard, or you might have a short somewhere. Disconnect everything from the reciever except its power cord and turn it on. If it still goes into protect mode, then try to find a reset switch (not sure if this is on the Sony, some recievers have them). If it's NOT in protect mode, then you had a speaker wire shorting out on the back. Make sure that you don't have any stray wires when you connect the cables on the back of your receiver. It only takes one strand of copper to short out the amp section. If that doesn't work then pull the top cover off and chech the fuses out. One of them might be blown.
Tom
Jan 01, 2009 | Sony STR-V555ES Receiver
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
767 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
