Question about HP Photosmart 4180 All-in-One Printer
C4580 shuts down when not in use, won't wake up.
It shuts itself down when inactive and cannot be awakened without unplugging it and then powering it back up.
I am running it on a new Mac powerbook.
  • 7 more comments
  • mlasswell Feb 14, 2009
    I have the same problem. Bought it with a new macbook. It goes on standby and won't respond to pressing any of the buttons. Like you, the only way to "wake it up" is to unplug and plug back in the power cord. Someone please help!
  • Guthrie25 Feb 23, 2009
    HP C 4580 shuts down after about 4 hours and won't wake up unless the DC supply cord is unplugged and reconnected.
    This happened when the printer was about two months old.
  • Anonymous Feb 24, 2009
    Make that 3 with the same problem with the C4580 printer.
  • sa gringo Mar 02, 2009
    Same exact thing here bought with an iMac and the only way I have to wake it up is to unplug and plug back in so I leave it unplugged until I have to print...
  • Anonymous Mar 07, 2009
    That makes 6 on this post. I have the same problem running on a pc wireless router. The printer goes to sleep after some period of inactivity and won't wake up. I have to unplug it and plug it back in to get it working again.
  • Anonymous Mar 11, 2009
    Same here, Windows based network. Bull5hit.
  • Anonymous Mar 16, 2009
    Same Deal
    Windows Based
  • Anonymous Apr 12, 2009
    Same....except it was that way right out of the box
  • Anonymous May 02, 2009
    same problem here
chiplevel
  • 656 Answers
SOURCE: My printer ( a hp
go to task bar you will see the printer icon click open and delete all the contents then first remove the usb cable then the power code replug the power cable and switch on the printer if the light is ok connect the usb cable also check the cartridge for low ink
Posted on Dec 07, 2010
Why will my surface tablet not turn on?
If you mean that nothing happens at all when you push the power button along the edge of the device then the battery is dead or the device itself is defective.
If it is off and you are just tapping the Windows button or using the keyboard to try to wake it then use the power button to turn it on first. It will sleep after idle for a time and can be awakened by the keyboard or the Windows key.
Hope that helps...
Jun 30, 2014 | Microsoft Surface RT
New Computer Shuts Itself Down
Call DELL support. Doesn't sound normal. There is Standby and Hibernate modes; neither of which would require you to unplug and plug-in the power cord in order to start the machine.
Dell support will have you run the Dell diagnostic at startup which will detect hardware problems. Or you could run it without calling...
Unplug power and remove battery
Press and hold power button 20 seconds
Replace battery, plug power cord in
Hold down the "Fn" key (to left of space bar)
Turn power button on while still holding Fn key
When diagnostics begins, let go of Fun key
Note any errors; let Dell know your findings
Jan 16, 2014 | Dell Inspiron Computers & Internet
HP DC7800 doesn't wake up (and power switch does nothing!)
Bad setting. If you press and hold the power button, the computer will shut off. That will keep you from having to unplug it.
Jan 28, 2013 | HP dc7800 Business Desktop Small Form...
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
My pc is shutting down and I can't wake it up without shutting down the power from power supply. The Antec 300 tower has two blue lights- the top light starts blinking when it has shut down and I
sounds like a power supply problem
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
hope this helps
Oct 13, 2012 | Antec Computers & Internet
Monitor goes to sleep after not being in use and then won't wake
Check the "power options" settingsin your control panel.
Nov 16, 2009 | HP W2007 LCD Monitor
After couple of hours unit shut itself down please help
in the manual it says the DVR will shut down after 3 hours of inactivity . The DVR should put up a message to " press enter " to reset .
hope , it helps .
Jan 20, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
HP Photosmart 4180 All-in-One Printer Logo
270 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
