Question about RCA 32F530T 32" TV
Why won't my T.V. turn on?
RCA 32F530T 32' T.V. It Hums, No Power, No Picture When I Plug it in?
    Scholar:
  • 167 Answers
Hello . it sounds like a high volatge problem . the tripler and the or the fly back transform. is bad. and thats what is huming. sound that you hear. time to get a new set. Good luck
Posted on Feb 08, 2009
No power rca model#32f530t
sounds like a blown fuse either in the plug or the tv , if so just need anew fuse
Oct 15, 2009 | RCA 32F530T 32" TV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
RCA 32f530t 32 inch tv
This has happened to me quite frequently. I have replaced the fuse at least 8 times. You just take off the back of the t.v. and on the bottom you will see a small glass fuse. just pop it out and go to radio shack and get a pack of replacements. about 4 for 3 dollars.
Jul 09, 2008 | RCA 32F530T 32" TV
Dead T.V.
iv come across that this model wasnt successful..try taking this tv back to the dealer..if nothingwrks..then its time u buy another one..srry
have a nice day!
tc
Jun 13, 2008 | RCA 32F530T 32" TV
RCA 32F530T
It could be several different things wrong, need to know if transformer {you think} has a big heavy insulated red wire coming out of it going to the picture tube, if so; that is the high voltage transformer. You will need a schematic to check out some capacitors, and transistors....the three areas would be problems with capacitors in power supply, the B Plus Regulation circuit, and check for rings around joints in that and overall on the main board and any connector joints that attach other modules to it, or plug into it, as well as joints associated with all plugs from wiring harnesses as well. Just guessing, sounds like a power supply regulation problem, and or joints that are ringy, rings around them or cracked ones. Hope this helps. T.
Jan 14, 2008 | RCA 32F530T 32" TV
Bad RCA 32 Tube TV
Bad IHVT ( HV transformer ) part # 257805 or ASTI 2078
......................................................T.
Dec 11, 2007 | RCA F32650 32" TV
TV won't turn on...
Probable bad flyback transformer or shorted cap in horiz circuit,
horiz output xistor suspect,also...................have tech check or
replace set....................T.
Dec 03, 2007 | RCA 32F530T 32" TV
Buzz When I plug the tv in I get a buzzing sound and the power button does not light up and there is no picture or sound.Could it be a tube?
quietlove,
I will guess you remember tube sets from our parents days !
They stopped being Mfr'd in 1972 !
Best solution for your set = replace horiz transformer and
transistor with RCA part # 's 257807 & 237470................T.
Nov 26, 2007 | RCA 32F530T 32" TV
Won't work
It sounds like something in the high voltage (flyback) circuit failed. If any little thing shorts in these RCA's they will not start up. Stargazer
Apr 15, 2007 | RCA 32F530T 32" TV
TV won't turn on
32F530TCD4
I received this solution:
"This was apparently caused by using replacement flybacks. Add a .001uf cap (102k@2kv) from RL03 (the side away from the FBT) to ground. This will shift the picture a little then compensate a little with parameter 15."
In my case, i used an other flyback the HR8934 from Diemen to get a more stable picture without blooming, and add a 440pF (two 220pF capacitor in parallel) instead of .001uf to eliminate the tearing lines.bfde541.jpgac61dec.jpgdda8fac.jpg.
Dec 01, 2006 | RCA 32F530T 32" TV
Open Questions:
RCA 32F530T 32" TV Logo
251 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
