Question about Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
I hooked up all new Sony components (Sony KDL-46V4100 TV & Sony bravia hdx576wf Home Theater) with no problems, even with our Motorola Comcast cable box. Loved the system for weeks, then one day no TV sound. I isolated the TV and the audio works ok thru the TV speakers. Audio is ok for DVD's and CD's and I can hear AM & FM thru the sony hdx576wf. I also isolated the cable box, hoping that was the problem. It operated fine thru another TV, sound and all! I checked the settings and all seems fine, but I don't understand the lack of TV sound. When I raise the volume on the TV alone, there is no sound (when hooked up to the hdx576wf). It's got to be something obvious, right?
Thanks, Brian
  • Brian Pirok
    Brian Pirok Feb 20, 2009
    pyrophile,
    Thanks for your input. Yes all three units are on. When I hooked the cable box to another TV, audio worked fine. Your right about the TV not overriding the audio system. The frustrating thing is that it was working for weeks before it stopped. The home theater unit is always on the TV function setting when I watch, or try to watch, TV. I'll try checking all the connections. I'm using the single source cables, not the colored RCA type cables and the digital audio cable (with the square plug). Maybe something is wonky. I don't think the kids knocked something out of wack, but nobody is admitting anything either!
  • Nahum Reduta May 11, 2010
    Are you sure all three components are on? If you're watching cable, the audio source is the cable box, and should output to the home theater. The TV shouldn't have any control over audio (unless you made a second audio connection from cable box to TV). The home theater should be in TV/Video mode, and controlled using the home theater remote.
    BTW, this discussion should help give the cable universal remote volume control over the home theater.
    Scholar:
  • 93 Answers
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Posted on Feb 08, 2009
Sound is not working on TV can it be a fuse
If picture is Ok, and problem is only with sound output, There aremainly three chances for this fault. Either the audio output section do not get proper voltage, or the audio output IC has damaged or speakers to the TV has damaged.
Jul 04, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
The sound on my sony bravia 46
If sound works with a DVD etc look for:
Speakers in set are switched OFF.
Sound on the set OR A CABLE/SAT BOX is turned down or off.
If no to all the above audio circuit in set is suspect.
Apr 27, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sound loss
Hello
Check the speakers of the TV. If they are OK, check the voltage that comes to the audio output section from the power regualtor section. If the voltage is also OK or seem shorted, the audio output IC of your TV has damaged and the section should be repalce as card basis.
Feb 27, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hi my sony bravia kdl-46v4100 model is decresing sound before i use 20% volume to hear it but now i use 40% of volume. What should i do? Can you guys help me? Thanks!
It's probably a station channel, channels broadcast different picture and sound quality, therefore when changing channels this can be noticable. It is probably not a tv problem.
Jul 02, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Need tv code for my sony bravia lcd tv for comcast remote
For silver comcast on-demand remote with motorola box: Sony 11100, 10000, 11317.
Hope this helps.
Apr 18, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a sony kdl-52S5100,and every so often when i switch channels i get only half a screen,{on the left side of tv}i can channel up and down abd it stays that way untill i push the input button on my...
I work for comcast have seen 2 kdl 5100 with same issue changed to component cables issue resolved
hdmi input is the problem. Yes I did try 3 different hd boxes same issue problem is with tv .
You are obviosly the third customer with this problem
May 17, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers Logo
586 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
