Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Tv out of focus
Showing two different colors could it be the digittal array how do you recet it or can u fix it yor self
  • dnlbal Feb 28, 2009
    dnlbal has a 57'' hitachi rear porjection it has a greenish blue picture with a red out line on it. screen is broken in lower right hand conner
  • Hitachi Master
  • 3,459 Answers
19a7683.gif Ecollier2012
Rank:guru_s.gif Guru
Rating: 91%, 106 votes
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be retv out of focus - 2c07611.pngs is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 09, 2009
    Scholar:
  • 167 Answers
Hello what you have is a converagrce problum. you need to replace the convergance ic chip's . they control the color that why it look's like that they will have stk4011 or something like that on them . good luck
Posted on Feb 08, 2009
  • 1 more comment
  • MICHAEL WALLACE
    MICHAEL WALLACE Feb 08, 2009
    hello what you have is a converagrce problum. you need to replace the convergance ic chip's . they control the color that why it look's like that they will have stk4011 or something like that on them . good luck
  • MICHAEL WALLACE
  • MICHAEL WALLACE
The Magic Focus does not work anymore.
The convergence has failed on your TV and will need to be repaired. You can call a shop or do it your self with a convergence repair kit from sites such as www.TvRepairKits.com . This is a failry common problem that all projection TV sets will have at some point.
Apr 21, 2013 | Hitachi 51F500 51" Rear Projection...
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
Colors are not focused. blurred picture. was told it was converganc. manual focus doesn't fix it. please advise if it's worth fixing. Fred C.
Yes,Ur tv convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300-$350 for parts and labors.
Apr 12, 2010 | Hitachi 61SWX01W 61" Rear Projection...
The tv will not automatically come into focus
U have pictures out of focus?Like pictures colors seperates in lines?Ur tv convergence are dead.U know how solders?Must replaced 2 STK convergnece ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Hitachi 43UWX10B 43" Rear Projection...
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Samsung rear projection tv has multiple images with differnet colors
The auto self focus screws up if the picture does not remain constant or close to it while focusing. It is designed to self focus every fifteen minutes. Go to menu and then setup and turn the auto focus feature off. I have had mine off for the past year and have had no problems. If you slide the bottom portion of the remote down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button during a scene and then hit the self focus button. It should align back up and may take a couple of tries. (If you have an aftermarket remote, just enter the menu and then setup and you can activate the self focus feature, just don't turn it to auto focus!)
Dec 31, 2007 | Samsung HC-P4752W 47" Rear Projection...
Green and magenta colors offset in picture
Sounds like convergence problems, set may have been moved lately and this can cause it. Did you try Magic Focus when the set was warm or did you try it when you just turn on? Set needs to be warm, before you try it. If nothing works you will need convergence kit
Dec 14, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Samsung HC-P4752W No Color
Do not automatically think you need to go into the service menu. I bet you 100 to 1 that you pulled out a plug or a connector somewhere OR one is not seated into the plug all the way. If the set worked with color before you messed with it, there is not a problem in the service menu. The service menu is not the fix all thing. it is there to make fine alignments and adjustments, and as a matter of fact, messing with a service menu even with the service manual is very dangerous. I have seen peeps ruin TV sets by messing around with the service menu alignments. STAY out of these alignments. they are not going to fix a problem that all of a suddenly comes up. Repair the problem in the circuit first. Good Luck
Sep 18, 2007 | Samsung HC-P4752W 47" Rear Projection...
Picture Looks Like a 3-d Movie
This is bad convergence. Try self focus and if still not ok is hardware problem. The STK are leaked and need to be replaced. It's not easy, you have to remove the all deflection board and for sure you'll have some resistors to replace too. I sugest you to call a tech, but first try the self focus.
Sep 17, 2007 | Samsung HC-P4741W 47" Rear Projection...
This tv has been a nightmare, its been down 3 times in 4 years.
The convergence board, AA95-01799G is available from http://www.samsungparts.com for about 122 bucks + shipping. You also may need to get the service manual so you can do the convergence alighnments with this set when you replace the board. You will also need the manual to perform the perfect focus alighnment on this set if you have that feature. Good Luck
Mar 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
209 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
