Question about Kenmore Elite 45986 Front Load Washer
F/32 error on my kenmore HE 4t elite washer
Washer goes for awhile then beeps flashing the f 32 error. pulled off panel and checked filter nothing.
  • matt_paland Feb 09, 2009
    now that I know the problem does anyone know the part # ?
    thanx. one more ? where is this located in the washing machine?
  • 640 Answers
Defective pressure switch..replace..onthejopb
Posted on Feb 08, 2009
  • onthethejob1
    onthethejob1 Feb 09, 2009
    part #8181695
  • onthethejob1
    take top off,,and in thev center under the croos panel ..it has a black tube running to it,,and a 6 pin connector,,
What does the trouble code f2 mean for the kenmore elite 4t washing machine?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 22, 2011 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
F02 problem
I can't think of what that error is off the top of my head and the owners manual would not tell you what that code means. Take off the bottom panel of the washer (3 screws underneath usually 1/4" or #20 torx) and the tech sheet is inside against the right sied or on the back of the panel. It will tell you what that means and some tips on what to look for. If you have any questions let me know.
Mar 08, 2009 | Kenmore Elite 45986 Front Load Washer
My washer is flashing sud...what do i do?
The following link explains the "SUD" error and how to correct:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
The error can be caused from obstructions in your drain pump (or lines) to using the wrong type (or too much) of detergent. Read through the link thoroughly and let me know what you find. This problem usually has a simple remedy that does not require a repairman. However, if you require additional assistance, or have questions, please let me know. I hope this helps you.
Feb 23, 2009 | Kenmore Elite HE4 Electric Dryer
Removing panel cover
Sounds like your drain pump is clogged.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore elite he 4t washer
I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
Feb 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He 4t washer
washer weary, You need to clean the filter on the pump. Remove the bottom panel and the filter will be right in front. 3 #11 torx screws it will pull down and off. Get yourself a bucket to catch the excess water. Unscrew the filter and clean it. Check to see that nothing is in the impeller. The F02 should go away..Catriver.
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
127 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
