Question about Webroot Spy Sweeper (spysweeper) for PC
Spysweeper program damaged after a.exe download
I was downloading some music when Spysweeper alerted me of a quarantine. Within a few seconds, my PC auto restarted and now it says the Spysweeper installation is damaged. I cannot reinstall...same error--to scan for the bug. Now, i cannot access any programs or copy/move any folders within the PC. I'm basically dead in the water... no Internet, email, no programs! The only thing that works is deleting files. I noticed an "a.exe" icon on the desktop---slightly shaded. I deleted the icon. Some readings on internet say to search for the a.exe process and kill it. It's not on my PC. Whatever this is it's well hidden. I looked at the running processes and found ISASS which some believe to be harmful. aall others seem ok. Do I delete it??? If it's not harmful, will this process automatically return after startup? Anyone have any solutions other than reformatting????
    President:
  • 2,559 Answers
Isass.exe is registered as the Optix.Pro virus which carries in it's payload, the ability to disable firewalls and local security protections, and a backdoor capability
How Do You Remove Isass.exe Files in Windows XP and Vista:
  1. Click your Windows Start menu, and from “Search,” click “For Files and Folders….”
  2. A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
  3. Type a Isass.exe file in the search box, and select “Local Hard Drives.”
  4. Click “Search.” Once the file is found, delete it.
How to stop Isass.exe processes:
  1. Click the Start menu, select Run.
  2. Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys ALT + CTRL + DELETE or CTRL + Shift + ESC.
  3. Click Processes tab, and find Isass.exe processes.
  4. Once you’ve found the Isass.exe processes, right-click them and select “End Process” to kill Isass.exe.
How to remove Isass.exe registry keys: (Do not delete anything other than what is listed below.)
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any Isass.exe registry keys, select “Edit,” then select “Find,” and in the search bar type any of Isass.exe’s registry keys.
  4. As soon as Isass.exe registry key appears, you can delete the Isass.exe registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete Isass.exe DLL files:
  1. First locate Isass.exe DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the Isass.exe DLL file is located. If you’re not sure if the Isass.exe DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the Isass.exe DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any Isass.exe DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did Isass.exe change your homepage?
  1. Click Windows Start menu > Control Panel > Internet Options.
  2. Under Home Page, select the General > Use Default.
  3. Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
  4. Select Apply > OK.
  5. You’ll want to open a fresh web page and make sure that your new default home page pops up.
Block Isass.exe sites: www.eKerberos.com
Stop Isass.exe processes:
Get rid of Isass.exe DLLs: %PROGRAM_FILES%\ eKerberos\ Hook.dll
Delete Isass.exe folders: %PROGRAM_FILES%\ eKerberos\
Please rate this a fixya
Posted on Feb 08, 2009
I want to uninstall spy sweeper but I can't. I get a runtime error. How can I uninstall?
Hi Friend,
Close the SpySweeper Program
  • If SpySweeper isn't closed properly, it may not uninstall completely. Click the SpySweeper icon on the Windows toolbar, then choose the "Exit" command to close it. Hold down the "Control," "Alt" and "Delete" keys at the same time to open the Task Manager. Select "Processes" and look for a process called "spysweeper.exe." If you find it, choose it and then click "End Process." Next, look for a process called "WRSSSDK.exe" and follow the same procedure to close it if you find it.
  • Uninstall SpySweeper
  • Go to the Windows "Start" menu from the toolbar, then choose "Control Panel." Locate the "Add/Remove Program" option and choose it. Once the list of available programs is populated, find and select SpySweeper. Click "Uninstall" and let Windows complete the uninstall process. You will get a message when it is done.
  • Test the Computer
  • Reboot your computer, and once it has restarted, look for the SpySweeper icon on the toolbar. If it is absent, hold down "Control," "Alt" and "Delete" to open the Task Manager. Under "Processes," look for "spysweeper.exe" and "WRSSSDK.exe." If the uninstall was successful, you will not find them. If they are running, end them and go through the uninstall process again
  • Mar 19, 2010 | Webroot Spy Sweeper (spysweeper) for PC
    Webroot spysweeper won't sweep
    This sounds like the program glitched. Try removing it and reinstalling. Then have it check for any updates.
    Aug 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
    I am trying to uninstall webroot spysweeper with antivirus but cant find it to remove it, what should i do?
    Under normal circumstances, like any other Anti-Malware software, Webroot will protect itself. You cannot randomly shut down its service. You cannot use most external uninstallers.
    Always try to uninstall it using Add & Remove Programs first (on XP) or Programs and Features (In Vista and 7), or the uninstall link in All Programs on your start menu.
    If you are not able to find it in any of these places, get the official cleanup utility from Webroot directly at:
    http://download.webroot.com/SSCCleanup.exe
    This utility is made to cleanly shut down and clean up Webroot SpySweeper, Antivirus, and Internet Security Essentials and will even remove itself when it's done.
    Dec 21, 2009 | Webroot Spy Sweeper (spysweeper) for PC
    I need to close spysweeper on my laptop in order to continue a download. How can I?
    Unless you have legal and fully licensed Spy Sweeper advise you to uninstall spysweeper and instal Spyware Doctor Starter Edition (Free). There is known fake named Spy Sweeper virus software.
    If it is oryginal do not ignore alerts! This software is to protect you and your computer against malicious software.
    Nov 26, 2009 | Webroot Spy Sweeper (spysweeper) for PC
    Spysweeper does not work when you click on it
    Web Root Spy Sweeper is an adware itself, this program install a key in the startupregistry with the name spy falcon, making you beleive that is a realadware .Sweeper auto quarantined some files need by the operating system............a better alternative is spyware terminator (click here) and is complete freeware8523dbf.jpg
    Jan 03, 2009 | Webroot Spy Sweeper (spysweeper) for PC
    Try doing a system restore to a day before you started having the problem.
    If that does not work, reinstall spysweeper.
    If still no luck that can be because of a virus or spyware yhat had damaged the spysweeper software , and probably also the system.
    The best solution in this case is saving all your data, then formatting the disk and performing a new system installation.
    Before formatting and reinstalling windows you can try the following software, it is one of most powerful, it is safe, and it is free.
    Spybot - Search & Destroy - Free software downloads
    Dec 31, 2008 | Webroot Spy Sweeper (spysweeper) for PC
    Webroot antispyware not sweeping
    if you are using webroot antispyware software on the computer. you have 2 resolution for that.
    1. if you have a CD then you can uninstall and reinstall it before that disconnect the internet connection.
    2. If your are downloading it online then the only thing is first try to download a different antivirus for the time being and then you can uninstall webroot from the cmptr and then you can download it again and then you can uninstall the antivirus which you installed for the time being.
    this will resolve the issue.
    Sep 13, 2008 | Computers & Internet
    Webroot spysweeper
    it is better if you change your spyware software.
    i think you have already understood why your pc is like that.
    otherwise restore the system to previous restoring point.
    Jul 25, 2008 | Webroot Spy Sweeper (spysweeper) for PC
    Webroot spy sweeper
    I did the live chat support. They were very helpful. Gave me a link to redownload the spysweeper product, since mine wouldnt let me do anything. It did work and my spysweeper is working great now. http://www.webroot.com/company/support/. Went to that site. requested a download and they sent it to my email right away.
    Apr 06, 2008 | Webroot Spy Sweeper (spysweeper) for PC
    Spy problems
    First Try This:
    Try to uninstall Spysweeper and reinstall (Control Panel -> Add Remove Programs)
    If it gets nasty reboot in to safe mode (follow these steps):
    1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
    2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
    3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the "Windows XP with networking"
    Once you are in safe mode do this:
    1. Download the free microsoft app "Autoruns" from http://download.sysinternals.com/Files/Autoruns.zip
    2. Extract the .zip file
    3. double click the file "autoruns.exe"
    4. The program will start autoscanning your computer to see what boots up with it (it will take a few min.... bottom left of screen tells you when it is done)
    5. Make sure you are in the "Everything" tab (which loads up by default)
    6. Hit CTRL + F (to do a Find)
    7. Type "Spy" and hit ENTER
    8. The first entry containing the word "Spy" in your startup instructions will be highlighted
    9. Look at the "Image Path" column, if it contains anything like "C:\Program Files\Webroot\Spy Sweeper\" uncheck that item
    10. Press F3 to see the next item containing the word "Spy"
    11. Keep repeating steps 9 & 10 until you get through the entire list
    I'm guessing you might find the following:
    C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
    C:\Program Files\Webroot\Spy Sweeper\SSU.EXE
    C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe
    12. Reboot as normal (spysweeper should not load up)
    13. Attempt uninstall, reinstall again
    Jan 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
    Webroot Spy Sweeper (spysweeper) for PC Logo
    379 people viewed this question
    Top Webroot Computers & Internet Experts
    Coss
    Mike
    Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
