Question about Sony Playstation 3 (PS3) Console
No sound with ps3 hdmi hook up
I have my ps3 hooked up under hdmi i receive a picture and sound from my tv ... but not from my receiver . my receiver is a sony dts it worked before we hooked up the hdmi cable what can i do ?
  • Anonymous Feb 17, 2009
    Same exact issue
    Problem Solver:
  • 6 Answers
Hey there, The same kinda thin happend with my surround sound have you checked under the audio options that the right cable is selected ?
Posted on Feb 08, 2009
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
No picture when hooking component through receiver. Get sound but no picture. Tried to put ps3 in input 1, 2 and 3. Tried multiple cables as well
with Denon you have to go into the menu and "assign" the inputs.
You have to select if you are using HDMI, s-video composite etc.
If your unit has upconverting remember that it will upconvert a s-video signal to HDMI but not the other way around.
HDMI is a digital signal composite, s-video etc are analog therefore you could not use the HDMI output from your PS3 but then use the red, blue green composite outputs from your receiver to run to your tv.
Dec 29, 2009 | Denon Televison & Video
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I have my PS3 and TV hooked up to the HDMI ports. I have programmed the unit to show them under TV and DVD respectivly. When I change the source to TV or DVD, nothing shows up on my TV as expected
Sounds like you hooked them both up to HDMI input ports. Make sure that the PS3 is connected to an HDMI input port on the AVR-1508, and that the TV is connected to an HDMI output port (not an input).
Oct 21, 2009 | Denon AVR-1508 Receiver
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
PS3 hook up to sony reciever
its in the sound settings on your ps3, change to hdmi out put, this should sort it, if not you can use your scart lead for the sound, just use red and white lead straight into your sound system or sony reciever. but you will need to set it up in the sound settings in your ps3. hope this helps
Feb 11, 2008 | Sony Playstation 3 (PS3) Console
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Sony Playstation 3 (PS3) Console Logo
200 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
