Question about Hotpoint HSS25GFP Side by Side Refrigerator
Not making ice fast enough in ice tray
There is a bar on the ice tray maker that goes up and down,but maybe its in the wrong spot,should it be under the tray,or will it automacticlly go where it should?
    Problem Solver:
  • 8 Answers
The bar should be all way down it shouldnt be under tray
Posted on Feb 08, 2009
  • popmon34 Feb 08, 2009
    the bar should be all way down it shouldnt be under tray
My ice maker isn't despensing enough ice fast enough to fill the ice bucket up
Ice makers spray cold water upward into cube shaped trays that freeze the water almost instantly upon contact . Then when you press the ice dispenser a heater comes on that releases the ice cubes from the metal trays. If it is very old replacement probably a good option.
Nov 27, 2017 | Refrigerators
Can it be repaired-not making ice
Ice makers can be repaired. Sometimes it is cheaper and more cost effective to just replace the entire unit for about 50 dollars or less on ebay.
If the freezer temperature is not low enough your ice maker will make ice in tray but not empty it into the tray since the interior temp has to be about 10 degrees for the thermostat to activate the unload cycle.
If there is no ice in the tray perhaps the water line to unit is clogged or the solenoid that feeds the water to unit is malfunctioning. Or, maybe the cam mechanism of the ice maker that controls the solenoid is fubar.
Mar 11, 2015 | Kitchen Appliances - Others
Ice Maker bar won't come down
I have not worked on this model before but on the whirlpool they have a bar as well. you can turn off ice maker by pushing it up and it locks in place to stop ice production. if u want it to make ice u push it up slightly and it should move down. also check the ice maker tray to be sure u are getting water to the tray. if u get the bar to go down and no water comes in then check that u have water at the back of fridge.. if u have water there but not in the tray then you may have a bad water inlet valve on back of fridge.
Apr 15, 2014 | Maytag MFX2570AEM French Door Freestanding...
U-LINE ICE MAKER NOT MAKING A FULL TRAY OF ICE AND CUBES ARE SMALL
HI.KATHY.if u got enough water then it must be the ice thermostat cutting out too early.hope this helps ali
Jul 12, 2012 | U-Line Icemaker
Won't make ice
If you have water coming to the ice maker, there are only a few more things that might be wrong. Here they are.
  1. Ice maker it's self is turned on.
  • either a switch or a bar that should be in the down position
2. Freezer has to be 5 degrees or lower for the maker to operate.
3. Heaters not working.
  • A heater at the bottom of the maker comes on to un-stick the ice from the tray. This is the problem if there is ice in the tray but it will not harvest or drop the ice.
4. Ice maker not plugged into the back wall well enough.
If neither of these are the problem, you need a new ice Maker.
Please rate this submission.
Aug 19, 2009 | GE Refrigerators
On GE refrigerator modelPSS26NGPB - it doesn't make enough ice. The tray should be full after a couple days but there's hardly any ice in the bucket and it is so slow coming out of the shute.
I believe there are three cycles in order to make ice. There is a switch that sends a signal to the water valve for the icemaker to fill. Then once the ice is made, heater under the tray comes on and the switch to turn the auger comes on for the ice to drop out. And of course, there is a over flow bar (on out side the ice maker) that can shut the whole process off until you physically push it down or is released as the ice level goes down. If any of these process malfunctions or any of the cycle is stuck, then you will not have as much ice or will not get any ice.
You almost have to listen to each cycle when you are home and check for each cycle WATER _ FREEZING _ ICE DROPING to see if you detect anything as what could be wrong.
Jul 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The icemaker won't make ice.
Try this,Open the freezer and look at the ice maker,there is a bar above the ice bin that kinda looks like a piece of metal coat hanger,Push it to the down position.If it is already down,Post back
Please take time to rate this fixya
May 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Not making ice
The filter does effect somewhat the flow of the water. For some people having problems with ice dispensing it may be as simple as lifting the metal shut off bar up and down. Then check the top of the ice tray to make sure no ice is stuck up there. When you move the metal bar up and down you should see the plastic dispenser that pushes the ice out turning or rotating. Hope this helps.
Dec 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
Marine ice maker
compressor is bad.
Jun 06, 2008 | U-Line Icemaker
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
61 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
