Question about Pinnacle Studio MovieBox USB Video Capture
I try to connect the Pinnacle MovieBox Deluxe (USB2) unit and it says "USB device not recognized" "One of the USB devices attached to this computer has malfunctioned and windows does not recognize it" Is this a driver problem or a Windows problem. Pls advise how to fix it as I have tried loading software few times and drivers (updates from the Pinnacle web site) and none have worked. I have connected it to various PCs and the same issue.
  • 2 more comments
  • shaileshpate Feb 08, 2009
    I have tried the removal and reinstallation of device drivers and they dont seem to help either.
    I have removed the device drivers and reinstalled device drivers (newer ones from their web site) and did not help either.
    Can you point me to the right driver set and latest sw for movie box?
  • shaileshpate Feb 21, 2009
    Has someone posted a new solution on Feb 17th? I can not find it.
  • 544 Answers
Thank you for choosing Fixya.com
please check firts if you follow this requirements.
  • Intel® Pentium® 4 or AMD® Athlon® 1.6 GHz or higher
  • 256 MB RAM (512 MB recommended)
  • Hi-Speed USB 2.0 port
  • Windows® XP, Service Pack 1 (SP1) or higher
  • DirectX® 9 or higher compatible graphics card (ATI Radeon™ or NVIDIA® GeForce™ 2 or higher recommended)
  • DirectX 9 or higher compatible sound card
  • 500 MB of disk space to install software
  • CD-ROM drive
  • Optional
    - CD burner for creating Video CDs or Super Video CDs*
    - DVD burner drive for creating DVDs*
    - DVD drive is necessary if you wish to install the bonus DVD containing electronic manual and bonus content(free version on CD-ROMs may be ordered on Pinnacle e-store - shipping cost not included)
    - Sound card with surround sound output required for preview of surround sound mixes
    - 16:9 compatible camcorder for capture of 16:9 video
*CD or DVD burner required
**Check if your Home DVD player can read VCDs & SVCDs formats
if you follow already this and still not working the problem now is in your driver try to shut down your Unit and re install again your USB.
let me know if what happen for your problem.
Posted on Feb 21, 2009
    President:
  • 2,110 Answers
Click select >run>type regedit
then goto
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
it will sove ur problem...it is a driver fault..
Posted on Feb 16, 2009
  • Sibananda Jena
    Sibananda Jena Feb 21, 2009
    It seems that many people are still getting the 'USB Device not
    Recognized' problem from time to time. Unfortunately there is no easy
    fix.
    Firstly, it's recommended that you make sure every one of your
    motherboard drivers are completely up-to-date, but you probably already
    knew that.
    In XP, after a USB port isn't used for a long while the USB driver
    built into the OS sets the OHCI controller to suspend. When you plug a
    device back in, it can sometimes fail to 'wake up' properly. This
    problem was supposedly fixed in SP1 but there is a related registry
    hack that may still be able to help.
    Run regedt32.exe and navigate to;
    A long shot perhaps, but I recall having similar problems with a
    USB hub built into my Microsoft keyboard and adding this key seemed to
    solve it. It wouldn't hurt in trying .
    Alternatively, removing all entries relating to USB in Device
    Manager and all associated USB drivers will force XP into refreshing
    the USB driver stack.
    Begin by unplugging all USB devices, then use Add/Remove Programs
    in Control Panel to uninstall any USB driver software. Next, boot up
    into safe mode and go to Device Manager. Once in device manager make
    sure 'Show hidden devices' is checked under the View menu. Uninstall
    all device entries in this order;
    1. USB peripheral devices (printers etc.)
    2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
    3. USB Root Hub(s)
    4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
    Then boot back into Windows (not safe mode) and it should populate
    the Root Hubs & Host controllers again. Proceed to plug your USB
    devices back in, starting with your powered hub. Be aware that most USB
    printers and scanners need to have their drivers installed first before
    you plug them in.
    Hopefully some of this may be of help, let us know how you get on.
  • 19,396 Answers
    President:
  • 2,559 Answers
This statement answers your question.
" I have connected it to various PCs and the same issue."
The problem is with the Pinnacle MovieBox Deluxe itself or the usb cable coming from it.
  1. Check the usb ends to make sure they are not damaged.
  2. Try a different usb cable.
  3. Make sure the computer has usb 2.0
You can identify whether your PC has Hi-Speed USB or not relatively easy.
Open Device Manager and expand the Universal Serial Bus section.
There should be an "Enhanced" USB host controller present.(if not just update the drivers)
These drivers are provided by the manufacturer, and may carry the maker's name (i.e. ADS, Belkin, IOGear, Siig, etc.). There should also be two "standard" version USB host controllers present as well. They are embedded in the USB chip which routes the differing USB speeds accordingly without user intervention. There are currently 7 manufacturers of the Hi-Speed USB host silicon themselves:
  • ALi (Acer Labs)
  • Intel
  • NEC
  • SiS
  • VIA
  • nVidia (shows as "Standard" controller)
  • Philips
Any other brand name that appears in Device Manager would likely be an add-in Hi-Speed USB PCI card. The makers above do not make add-in cards, but they do make the chips that are used in them.
Posted on Feb 08, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A few ideas to consider:
  • have you tried replacing the USB cable?
  • do the LED lights up on the Pinnacle MovieBox Deluxe when plugged in/powered?
  • if the unit has been in service for some time, you may want to check the hardware; that is open the unit and check for a any cold solder issues either on the small USB connector or the power/regulator circuitry.
Would appreciate any updates. Good luck and thank you for using FixYa.
  • 470 Answers
Try to check the USB hub,, the problem on it is the hardware of the CPU,, just testing another USB and observe it, if it will do the same therefore the USB hub need to replace, or just insert it into the USB hub at the back of the CPU
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Mar 04, 2009
    did the solution are satisfied to you??
  • 350 Answers
  • 217 Answers
It can be the hardware or the windows or the drivers or even a wrongly configured bios.so please try this
  1. Unplug and then plug in the device.
  2. If the computer prompts you for a device driver, read the information that was included with the device, or visit the manufacturer's Web site to see whether a driver is available.
  3. Run Windows Update to obtain the latest fixes for Windows XP. When this is complete, plug in the device to see whether it is installed correctly.
  4. Also consider flashing bios
  • Saroj Sharma
    Saroj Sharma Feb 21, 2009
    please click here to find all the details about how to install and where to download the required software for your Pinnacle Movie box Deluxe
    http://tinyurl.com/pinnaclemovieboxdelux...
    Please do check the hardware and the cable for any physical damage also
  • 6,784 Answers
If you are running vista, you may need to update your hardware with vista capable drivers. if you are running xp, you will need to update the usb driver sets. make sure you have the latest movie box software as well.
    Sergeant:
  • 250 Answers
It looks like sftware problem but try uninstalling usb drivers from devicemanager and then reinstall them again and then check wether the device gets recognised .
I have a pinnacle moviebox 510-usb. The specification contains, you can streaming from analog secam source, but in importer section i can't see any video after switched secam mode, while the vcr play...
Be sure that your MovieBox capture device is selected under Studio's "Setup/Capture Source" selection (assuming you're capturing analog). If the MovieBox doesn't show up in that selection window, there could be a problem with the device.
Additionally, check in the Diskometer left-hand panel (this is found at the center of the bottom of the screen) and see that the correct input port value (either composite or s-video) is selected.
If you're capturing digital, then you'll have to use a Firewire connection to the MovieBox device.
Hope that's helpful.
Dec 31, 2010 | Pinnacle Studio MovieBox Plus - Video...
I need a MovieBox DV (1394)driver compatible with
Pinnacle Software has a Vista Patch to use with their applications that you have to download and install. I had this same problem when I used Pinnacle for my remote camera system.
Jun 25, 2010 | Pinnacle Studio MovieBox DV 9 (210100349)...
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
Dec 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
Does moviebox usb work with studio 14 on vista?
i want driver for pinnacle movie box deluxe usb on windows seven7 thanks
Boot system from external hard-disk with USB2
You can check the bios and make sure that it is set to boot from USB. Turn computer off. Turn back on and immediately press F2. This will get you into the BIOS. Look around and find boot properties. Set the boot first to USB. If you do not see the USB option, then your motherboard doesn't support the boot from USB option.
May 09, 2009 | ASUS P5GD2 Deluxe Motherboard
Pinnacle Moviebox Deluxe - Error "USB Device Not Recognized"
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU!
Feb 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
Moviebox Power Adapter
If you call Pinnacle, they may have a spare .. I thought Iost it and called them. They had it and would sell it for $15 (includes shipment).
Dec 17, 2007 | Pinnacle Studio MovieBox USB Video Capture
Pinnacle MovieBox USB Power
You can use a universal one but it has to be 3.3 Volts at 3 AMPS and the tip of the plug must be positive. If you have a radio shack by you they should be able to get you the correct adaptor.
Thanks,
Mark
Nov 01, 2007 | Pinnacle Studio MovieBox USB Video Capture
Pinnacle Studio MovieBox USB Video Capture Logo
243 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
