Question about Microsoft Xbox 360 Elite Console
2 red and 2 green light are blinking!!!
When i start my xbox 2 red light in the upper and 2 green ligts in the bottom of the power button blinking. After it has blinked the 2 red in the upper and the 2 green in the bottom changes place and and the 2 green blinks in the upper and the 2 red blinks in the bottom and its keeps changin all the time and the picture doesn't come. before it did like this i had the ring of death, 3 red lights and i did the towel trick, after that it had been like this.
pleeease help meee!!
  • 1 more comment
  • Anonymous Mar 07, 2009
    i had the 2 red rings not under warranty so i tried to fix my xbox myself, i replaced the thermo paste then put everything backtogether and got the same problem. 2 red, 2 green interchanging lights!
  • Anonymous Mar 18, 2009
    I have the exact same problem, with a Xbox 360 Elite..
  • Anonymous May 01, 2009
    i have the same problem, have u fix ur xbox yet?
I have this problem also and I just got it back from microsoft. I sent it in for a disk drive repair cus it wudnt read my disks and i just got it back and this happens. I didnt tamper the system or anything and it was still covered by warranty but they are saying in a letter that was in the box that something was no covered on the warranty for something. Help???
Posted on Feb 22, 2010
This error means that data in NAND corrupted.
Posted on Jan 14, 2010
Ive had that happen to me all u have to do is buy a new hard drive it worked 4 me but dnt get mad if it doesnt work 4. u because it doesnt always work!!!
Posted on Mar 05, 2010
    Sergeant:
    Champion:
  • 378 Answers
Its Overheating. Is it covered under the ms waranty? If not we can try a reflow on the system if you didnt already melt the solder together under the chips. I do not recommend to anyone to try the towel trick. It can permanently damage the system. Here is our website. We are a listed repair service on this site.
www.videogamerepairservice.com
xbox360fixer@verizon.net
Posted on Feb 08, 2009
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
I cant get the xbox to work from the controllers, when i press the "x" button on the controller it just keeps flashing and doesn't allow me to link up with the console
The "x" button is the xbox guide button that is in the center of your controller.
1. First, turn on your console by pressing the power button on the console itself.
2. Next, press the xbox guide button that's on your controller. (The button that lights up and flashes when you press it).
3. On the front of your console, just to the right of the memory card B slot & just below the right corner of the DVD tray, there is a small, round connect button.
4. With the both the console & the controller on,(lights flashing) press and release the connect button on the console first.
5. Then on the controller, press the connect button (green arrow, circled in red) that's between the Left Bumper button (LB) and the charging port (blue arrow).
6.The lights on the controller and on the console should continue to go in a circle and stop.
7. The upper left quadrant is controller # 1, the upper right quadrant is controller # 2, bottom left is # 3, and the bottom right is # 4.
8. Once the controller connects the the console,you're all set. Then the next time you go to turn it on, just press the xbox guide button on the controller and it will turn the power on to the console for you.
9. If you ever take your controller and use it on another 360 console, you have to go through the same connection steps as you just did. And then again, when you get back to your console
Hope this helps! Happy gaming!
Dec 17, 2009 | Microsoft Xbox 360 Console
Wont load,blinking red light on the power button
if it is the top left, bottom left and bottom right lights blinking red, this means that there is a hardware failure in your xbox 360 and there is no current way to fix this. i recommend that you send it in to xbox to see if they can do anything, and if not, they will possibly send you a new xbox 360.
Sep 27, 2009 | Microsoft Xbox 360 Console
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
Original xbox red ring of death
you have to take the xbox apart open the dvd/cd rome and clean the eye and the disk spinner then put it back together and it should work fine
Dec 28, 2008 | Microsoft Xbox Console
2 red lights w/green light
The problem is the black screws on the bottom of the frame that screw into the X-Clamps. Most of the time, you usually don't have to even put the black screws back in. However their can be exscruciating headache inducing problems with fine tuning the black screws. If you do end up needing to put the black screws back in, I suggest to start with one @ a time, starting with the bottom right screw. ( thats with the 360 standing vertical with the dvd drive faced toward U.) The tightness can range from almost as tight as you can possibly get to soooo!!!!!! loose u can't possibly imagine how its doing anything at all. The best way to do this is, with the 360 hooked up, (and the case left off) take the small white plastic frame off that covers the power button, start with the screw loosened and then proceed to turn slightly like an 1/8th of a turn, then power on and then turn off if 2 red or 3 red ring proceeds and then repeat. You shouldn't have to put all the black screws back in, mine only has bottom right bottom left and top left, and are incredibly loose. My friend however has bottom right only and is tightened only about 1/2 way.
Sep 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 is flashing 3 red lights and doesnt play
Hello there.
Please click http://support.microsoft.com/kb/907534 to see about this problem.
As per the page:
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue: 1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Xbox 360: The power supply light is red 906102 (http://support.microsoft.com/kb/906102/) Xbox 360: The power supply light is orange 906103 (http://support.microsoft.com/kb/906103/) Xbox 360: The power supply light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again.If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support), and then click Console Repair? in the upper-right section of the Web page.
Hope this helps.
May 26, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Elite Console Logo
719 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
