Question about Kenmore Dryers
Clothes Arent Drying
My element lights up, the drum spins, air flows out the back (when I remove the vent) yet I have to run 2-3 cycles for clothes to be dry.
  • 135 Answers
Try running a load without the venting connected. Your venting may be plugged. If that isn't it, check the heat element. Inspect it for a break. It may heat partially if it is broken and touching the housing. Hope this helps!
Posted on Feb 08, 2009
My whirlpool dryer model ler3624jq1 type d433-ele-2406028-fm54 isnt drying my clothes completely
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Jun 17, 2012 | Dryers
Dry takes a long time to dry cloths
May 28, 2012 | Kenmore Dryers
Needs two cycles to dry clothes!
May 19, 2012 | Kenmore Dryers
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
I have a Whirlpool dryer - Imperial series. The dryer is 5 years old and we have already had to replace the heating element 1 1/2 years ago. Now the dryer seems to get hot but won't dry the clothes. It...
Good day,
Dirt. First step is remove the vent system, and test performance. If that's it, either clean or replace the vent system.
If that is not the problem, remove the lint filter, remove the 2 screws under it. With a screw driver, at each corner of the front of the lid, pry up the lid off the clips and prop up.
Now go to the rear, and remove the back panel. On the left side the air chute housing is held on with screws. Remove the screws and pull the housing out and up as far as possible.
Clean all lint build up in that area especially around the blower wheel. That should solve your problem.
Here's a picture of the back of the machine.
Sep 18, 2010 | Whirlpool Dryers
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Dryer must run two complete cycles to dry clothes
the first thing to checkis the duct venting and make sure it is not clogged or blocked. when the dryer is running go to the outside of the house where the dryer venting is and look at or feelthe amount of air flow coming out.if the air flow is weak there is a restriction somewhere.if the air flow is good and strong then check the heating element. also the washer may not be spinning out the clothes properly
Jan 24, 2010 | GE DBSR453EBWW Electric Dryer
Dryer spins, air flows through vent but isn't hot
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Sep 15, 2009 | Whirlpool LER7646E Dryer
Dryer that will not dry well
One of two things... An almost totally blocked vent to the outside or a bad heating element. Remove the vent form the back of the dryer and get a "feel" for how much air flow is coming straight out without any venting connected. Then connect it back up and with the dryer running, go outside and give it the "feel test" judging as close as you can the percentage of air flow loss through the house venting. Anything more the 30% air flow loss will cause the dryer to take forever to dry. As far as the heating element, on a Whirpool, it slides up into a plenum in the back as kind of a rack type assembly. Not that difficult to replace by remove wire connecting to it, thermostats attached to it and (probably) two screws that are securing it in the plenum.
Dec 20, 2008 | Whirlpool Washing Machines
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
