Question about Whirlpool Duet GHW9150P Front Load Washer
Error messages during cycles
I keept getting error messages during the wash cycles. Either flashes DL or F. Often cannot open the door when this happens.
  • 2 more comments
  • Anonymous Feb 09, 2009
    F- message during the wash cycle or a D message. Have to drain and spin several times before it finally ends the cycle. Any suggestions?
  • Anonymous Feb 11, 2009
    error code F02 cycle never completes clothes are not draining, unplugged it several times , still same problem, please help
    whirpool duet front loader washer
  • JOYCE BROOKS May 11, 2010
    hi my name is joyce
    what model do you have? you can go to maytag if you have a maytag.com and download the code book and look this up and find out what is going on with your machine, you can unplug the machine from wall for 1 min to reset it or push pause cancel 2 times but this may not help what the problem is. always use HE detergent if you are not using this make sure to buy it and use it ony it because if not it will cause problems in your machine pump. you machine will keep trying to rinse the detergent out of the clothes and it will just keep on running.
    hope I could help
    thanks
    joyce
  • 5,911 Answers
To all that have posted under this request: You should always try to reset the Central Control Unit (CCU) before assuming you have a component failure on these front load washing machines. In many cases these error codes can be erroneous and resetting the CCU will correct the problem. To reset the CCU, the washer must remain unplugged for AT LEAST 30 minutes. This is verbatim from the manufacturers technical data sheet. If the error code reappears, then more than likely, you have a legitimate component malfunction.
"Fdl" is usually caused by a door latch failure (but in some circumstances be caused by a failed CCU). If the door latch fails to lock, the washer will not complete the cycle.
"F02" is usually caused by obstructions in the drain pump causing a slow drain. You must clean out the drain pump reservoir and check the impeller for debris.
NOTE: The later models of Maytag are manufactured by Whirlpool, using Whirlpool parts and electronics. The error codes and method of correcting them are the same.
I explain all these error codes under the "Tips and Tricks" section of my profile. If you cannot find what you are looking for there, please use the "Ask Me" feature and I will do my best to provide you with a solution.
Posted on Feb 14, 2009
In many models there is a "technicians only manual" under the top cover of the machine that lists solutions and explains all the error codes. You can get at the manual by undoing the screws on the top at the back of the washer, don't worry you can't mess anything up its really a pretty empty box once you look inside. The way I fixed my f02 and sud error messages was by undoing the three screws at the very bottom ofthe washer and removing the bottom panel (7mm quarter inch drive socket and 2 inch extension) there is a filter housing that looks cylindrical, unscrew that (there is a lot of water in there so watch out) and clean the filter, feel the drain line coming out of that filter and make sure it is clear, if not poke a wire hanger through to push all the debris out, reassemble the opposite of disassembley, run a load through and then repeat this procedure to make sure all the debris is out of the lines and this should fix the error messages.
e-mail me and I'll send pictures if this description is hard to follow
aliciasramsey @ yahoo. com
Posted on Aug 03, 2009
What does F DL means i opened the door to add something then t came up F DL and wont start again, the cycle had just started I pressed cancel all it does is beep and flash F DL
Hello and welcome to FixYa
FDL is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Sep 14, 2011 | Whirlpool GHW9400 Duet Washer
Get DL ...F ERROR CODE
hi,
Error dl f --
Condition:
Door Lock Error-
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check/Repair:
1. Door Lock Mechanism broken or removed from the Door.
2. Check Door Lock/Switch Assembly.
3. Check the wire harness connections to the Door. Lock/Switch Assembly and Central Control Unit (CCU).
4.Door Lock/Switch Assembly Failure.
good luck....
Mar 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code on the washer machine
DL/F is a door unlock error the door lock may be broken.
Mar 18, 2009 | Whirlpool Washing Machines
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What do I do for dL and F error message?
same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
Jul 17, 2008 | Kenmore Elite 45986 Front Load Washer
Not drain
DL is the fault code for door lock error and occurs if the CCU (Cental Control Unit)"recognize" that door is unlocked. Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit and to the CCU. - Door Lock/Switch unit Failure
Jul 21, 2007 | Kenmore 43142 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
427 people viewed this question
Dan Webster
Dan Webster
Sal De
