Question about Hotpoint RB757 Electric Kitchen Range
My oven has been on Auto self for 7 hours. How do I shut it off?
I just want to know how I can turn it off. It's making the whole apartment hot and I need to know how to turn it off.
I just google any answer i am looking for....example how to turn off auto self clean over worth a try
Posted on Mar 05, 2009
Door won't open after Self Cleaning Oven
if you are facing this problem still yet, I suggest that call a service guy to fix it and turn off the power.
Apr 19, 2013 | Electrolux Kitchen Ranges
Actually I have a dual.....I started self cleaning about 1 hour ago now I have to leave and there was a small and wanted to turn it offf so I did and now the door is still lock and it says hot.....but that...
When ovens self clean, the temp rises past the highest temp you can set it at. It is burning everything off, to clean the oven remember. Yes, it is safe to leave. The ovens have a safety, which will shut the oven off if the temp gets too high.
Mar 31, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
Put oven through self clean for 2 hours. Oven
What has happened is IF the temp gets to hot in the electronic controls area, an in line fuse/limit burns out and shuts down everything.
I have a DACOR tech sheet HERE
So what I think is happening is the in line fuse in the wiring harness could be blown. You won't know till you or someone checks.
Jan 15, 2010 | Dacor Ovens
Oven shuts off when the door opens
Turn breaker off for 5 mins. then turn back on, this will clear the memery and take it out of self clean.
Please rate solution
Sep 05, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
Self cleaning oven directions
MAKE SURE OVEN IS EMPTY LOCK OVEN DOOR AND TURN OVEN SETTING TO CLEAN, IF YOU HAVE A VENT TURN IT ON THERE WILL BE SMOKE! LET RUN TWO HOURS,TURN OFF,LET COOL BEFORE TRYING TO UNLOCK IT (WILL NOT UNLOCK WILE STILL HOT!) OPEN DUST OUT ASH ITS CLEAN!!!
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Self Clean won't start - Amana ACS3350AS Gas Kitchen Range
Our door on this oven is coming apart, so the oven door never truly closes.  When you set the self clean cycle, push the door shut until it locks... at least this has worked for me.  But I think all your problems, which are similar to mine, result from the oven door not truly closing... heat escapes, so the temp is not right and takes forever to heat up.  The heat melts the control panel, causing other problems.  In fact, our door is starting to fall open... a bit dangerous.
May 06, 2008 | Amana ACS3350AS Gas Kitchen Range
Hotpoint Self Cleaning Oven
the oven has a feature where you set the time for it to begin cleaning and the time for it to end cleaning.
Next to the clock in the middle of the back are two dials. The top one is the start time, the bottom one is the end time.
I suggest 2 hours to allow a good cleaning.
The locked light will turn off when the cleaning is done, allowing you to open the locking lever.
Jan 17, 2008 | Ovens
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Hotpoint RB757 Electric Kitchen Range Logo
108 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
