Question about SpeakerCraft BassX-10 Subwoofer
Blowing fuse My Speakercraft BassX12 started blowing fuse about a month ago. I figure the AMP must be shot. Can I get a replacement AMP rather than replace the whole thing. I'm hoping it would be cheaper. Tx
  • Anonymous Feb 10, 2009
    I have the same problem with my BassX-10, continues to blow fuses.
  • 50 Answers
I once rigged and old audio vox 8 inch sub into a box for a 12 inch cerwin vega had the same issue i just stepped the fuse from a 15amp to a 35amp had no problems after that.-z (you could also just solder the two wires for the fuse holder together if you have them eliminate the fuse or put a bigger fuse in).-z
Posted on Feb 21, 2009
2005 mazda trubute won't start and i replace 40amp and got it work and it drive for a while and then it blow again
Mazda Tribute Questions - CarGurus
www.cargurus.com > Questions > Mazda
CarGurus2001 Mazda Tribute 3.0 Wont Start. out shopping one ... 0. Report. rebel54 asked a2005 Mazda Tribute i Maintenance & Repair question about a month ago ...
Tribute won't start - Mazda Forum - Mazda Enthusiast Forums
www.mazdaforum.com > ... > Mazda Vehicles > Mazda Tribute
May 22, 2007 - I have a 2002 Mazda Tribute V6. On Sunday it wouldn't start. ... 2005Tribute won't start! rizakag, Mazda Tribute, 4, 03-27-2006 09:29 AM ...
Why does my fuse in my 2005 mazda tribute keeps blowing ...www.cargurus.com > Questions > Mazda > TributeCarGurusSep 4, 2014 - Why does my fuse in my 2005 mazda tribute keeps blowing when I try to switch gears?Electrical problem - 2004 Mazda Tribute - RepairPalrepairpal.com > Questions > Mazda > Tribute > 2004 Mazda TributeApr 5, 2011 - Electrical problem on 2004 Mazda Tribute ... meter on the battery cable note the battery draw then remove fuses one at a ... 2005 Mazda Tribute.2005 Mazda Tribute, Fuse #3 Blows, No Tail Lightswww.sparkys-answers.com/.../2005-mazda-tribute-fuse-3-blows-no-tail.h...
Jan 30, 2016 | 2005 Mazda Tribute
Blower motor fuse
always start on a switch when they all they cause that
Nov 13, 2013 | 1998 Mercury Mystique
My #20 fuse in the engine compartment is blowing, which is a 15 amp fuse
You look up the circuit that blows the fuse in your owners manual
You then need wiring diagrams to figure out why a fuse blows &
solve the problem,you don't replace the fuse, only to have it keep
blowing
Feb 08, 2013 | 1999 Ford Windstar
Can a bad voltage regulator cause the main 30 amp fuse to blow?
Usually a bad regulator will only cause problems with charging...
Sounds like you've got a short somewhere in the wiring...I'd start by checking the ignition switch wiring and the connections going into the fuse box.
Mar 19, 2012 | kawasaki VN 1500 Vulcan Classic...
99 lumina keeps blowing 5 amp starter fuse, I changed starter about 6 months ago and it quit , now it has started blowing it again. Only sometimes. Will start when I jump starter if fuse blows.it has...
Replace the starter relay in the fuse box behind the glove box. The fuse ONLY powers the control coil portion of the starter relay. If it's blowing, there's a short in the winding or a short between the relay and the theft deterrent module. Bad relay is most likely culprit
Jan 05, 2018 | 1999 Chevrolet Lumina
The fuel injector fuses keeps blowing as soon as i open the ignition switch, it dosent even give me time to turn on the car before it blows again. the car has a new fuel pump installed by jiffy lube about...
There is a short circuit to ground on one of the circuits that the fuse protects. I need more information about your car and exactly which fuse is blowing. (Year, Make, Model, Engine size) All of the circuits powered by that fuse must be traced to find exactly what is causing it to blow. Most of the components can be eliminated as the cause by unplugging them one at a time and checking the fuse connector with a test light. (Otherwise, you could go through a lot of fuses trying to figure it out.)
Dec 24, 2010 | Kia Spectra Cars & Trucks
2004 pontiac vibe AM2 fuse blows regularly
Did you get a response to this? I have the same problem.
Feb 06, 2010 | 2003 Pontiac Vibe
Blowing Fuses
your starter is going bad have it check out,
Dec 18, 2008 | 2003 Ford Focus
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
ECM BATT fuse keeps blowing
That fuse provides power for the fuel pump. Either your fuel pump is blowing the fuse or there is a shorted wire.
Nov 22, 2008 | 1995 GMC Jimmy
SpeakerCraft BassX-10 Subwoofer Logo
421 people viewed this question
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
James Oliver
Level 1 Expert
Craig Butler
Craig Butler
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
