Question about Haier Dishwashers
I just purchased and installed an Haier ESD 210 dishwasher. Everything seems to work fine except the machine will not shut off. Also, after selecting the "wash program" the LED blinks continually during all cycles. It takes some effort to latch the door but it does lock. Can you help? Thank you. Joel Miller (millerstwo@aol.com)
  • millerstwo Feb 08, 2009
    I hope the answer to my question is not "are you sure the dishwasher is level". This info is in the installation instructions that came with the dishwasher. Of course the dishwasher is level, I don't need to spend $17.95 for someone to read the installation manual for me. Can you guys help me or not? Let me re-post my question....
    I just purchased and installed an Haier ESD210 dishwasher. Everything seems to work fine except that the machine will not shut off. Also, after selecting the appropriate "wash program" the LED above the selection blinks constantly through all cycles. It takes some effort to latch the door but it does lock. Can you guys provide some help with a cause and effect answer?? Look forward to hearing from you as soon as possible, thank you.
    Joel Miller
    (millerstwo@aol.com
  • millerstwo Feb 13, 2009
    I tried everything you recommended except the final suggestion which was "since new, call for warrantee service or ask for replacement". I'm returning the damn thing, great suggestion. Sorry it took so long to get back to you as I am accepting you excellent solution. Thank you for your expertise, if I require help with another project in the future I will definately contact you. Thanks.
    Joel Miller
    President:
  • 2,559 Answers
This can be caused by water temperature.
Please Make sure that the water supplied to the unit is 120 degrees or higher.
This can be checked on the hot water heater thermostat setting.
Posted on Feb 08, 2009
  • Haier Master
  • 19,396 Answers
When the machine does not shut off, that is because the cycle cannot complete drain, and the timer does not reach the end of the cycle.
If you manually advance the timer and open the machine, you should get water at the bottom.
This means that either the drain system, the water level switch, or the timer control have a fault.
Check first the drain system, check lines, drain filter if present, and ensure drain pump is working.
Check that the floating switch is not broken or stuck.
If the drain system and water level switch are fine, then replace the timer control board.
You find replacement parts here.
Regards
  • Ginko
    Ginko Feb 08, 2009
    An additional thing, if you get "will not shut off. Also, after selecting the "wash program" the LED blinks continually during all cycles." that means that there is a problem, and as I explained probably parts to replace.
    If the machine is new the most likely , instead of drain pump, like on a used one, it is a factory defective control assembly.
    Being the machine new my suggestion is calling the number listed on the owner's manual to get support, servicing the machine by yourself may invalidate warranty.
    For details on what the problem can be, see my previous comment in your email.
  • 679 Answers
Put some towels dowm and tip the dishwasher over to one side about 45 degrees, if water pours out of the base it means that the dishwasher is in "flood mode" and you have a leak into the base that will need resolving.
Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of ideas:
  • check that no piece of plastic tape/wrapper/packing got lodged inside the door lock slot;
  • check the hinge and/or door lock tab. It may have been misaligned while in transit;
  • check that there are no leftover locking tiedown, tape or clamps. Some versions/models have such in place when unit is new to prevent excessive movement of certain parts when being delivered/transferred from one place to another;
  • check your wiring/breakers. The heater may not be getting power, the unit senses water temp is not as it should be and therefore "waits";
  • since new, call for warranty service or ask for a replacement.
Would appreciate any updates or developments. Good luck and thank you for using FixYa.
    President:
  • 1,902 Answers
Are you sure that the unit is level?
The dishwasher isn't getting water in?
The inlet solenoid may be stuck. Or the screen in the inlet connection may be plugged.
Jan 12, 2015 | Dishwashers
Settings buttons partially work and will not start
Basically, the Haier is a piece of ****. Parts are not available and the phone-in service (if you can call it that) will keep you on hold endlessly. Do yourself a favor and get a better machine.
Apr 19, 2010 | Haier ESD400 Stainless Steel 24 in....
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
Haier buttons not working!
From previous experience, I would bet that the circuit board/ control panel is failing. The one I had leaked steam near the top of the unit and the condensation will work it's way into the top control panel. Bad design on Haier's part. The worst part about mine was there is no adjustment for the door. I ended up getting a refund on the unit and buying a very nice LG model. Good luck dealing with Haier. They will send A&E factory Service out and they are not very good. I would suggest getting rid of the Haier. (personal opinion)
Jun 01, 2009 | Haier ESD400 Stainless Steel 24 in....
Dishwasher will not empty
check to make sure nothing is binding the impeller, ie: broken glass, coins, twist ties, plastic bag.
Jan 18, 2009 | Haier 17 in. HDT18PA Built-In Dishwasher
Gate way 210 projector
needs cleaning. and the signal needs to match the source (laptop). go into the menu to adjust.
Dec 05, 2008 | Gateway Projector 210 Multimedia Projector
Will not complete wash cycle
I had a similar problem, except I did not notice a burning smell. I would put my dishwasher on and it would stay on the wash cylce for ever. I had to manually turn the dial to the next cycle.
I had a repairman in and told him I thought it may be the thermostat (from everything I had read online). He dismissd my diagnosis and said it was the timer. He order the timer and came back 2 weeks later and replaced it. It did not solve the problem. He then ordered the thermostats (my Haier ESD102 has 2 of them) and came back 3 weeks later and installed them. That solved the problem!
Timer = $137 CAD (covered by warranty)
Thermostat 1 = $14 CAD
Thermostat 2 = $21 CAD
Jul 19, 2008 | Haier 24 in. ESD100 Built-in Dishwasher
Pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Feb 03, 2008 | Haier HDP18PA Stainless Steel...
Dishwashers Logo
Top Haier Dishwashers Experts
Chen Dorot
Chen Dorot
Tim Doolittle
Tim Doolittle
Bill Boyd
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
