Question about Troy Bilt Walk Behind Chipper/Shredder/Vacuum 205cc
Troy built chipper/shredder won't start
I ran shredder and forgot to check oil. Ran out of oil and had small amount of smoke from oil part. Now the pull cord seems a little slack and the shredder will not start. Is the motor blown. Can I repair it. This shredder is just over a year old.
  • djay01 Feb 15, 2009
    sorry took so long to rate you was out of town for couple of weeks. thanks so much!!!!
4 Suggested Answers
  • 10865 Answers
SOURCE: Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Posted on Apr 23, 2009
  • 47 Answers
SOURCE: 10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Posted on Jun 22, 2009
  • 1129 Answers
SOURCE: How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Posted on Jul 14, 2009
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Have a troy bilt model # 47282 hard to start what could it be
is the gas any good?is it newer than 30 days old gas is only good for 30 days in small engines
Apr 24, 2012 | Troy-Bilt Chipper Shredder
Location for adding oil?
Most small engines have a cap where you check your oil level. This is also the access for putting in oil.
Here is a link to the Troy-Bilt site for chiper shredders. I don't know what model you have but you can select your model and obtain a users manual.
http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54996_54995_54995_-1#
I hope this helps you. Good luck!
Jul 08, 2010 | Troy-Bilt® Briggs and Stratton Chipper
I PICK UP A 3250 TROY-BILT GEN AND RAN IT 1 FULL TANK OF GAS OK. THAN WE GOT A SECOND STORM FILLED TANK AGAIN LET RUN FOR ABOUT 6 HOURS AND IT STOPRD. WHAN I THAUT IT RAN OUT OF GAS I REFILLED AND TRYED TO...
pull plug and try to pull start if moves than it was vapor locked clean plug and try to start if no movement with plug out than internal engine or pull cord jammed
Mar 03, 2010 | Troy-Bilt® Briggs and Stratton Chipper
I have a troy built 250cc chipper shredder.. it
hi yes you can. when you take the back off you can reach the cuttingwheel and clean everything. after that its ready to use again.
Jan 30, 2010 | Troy-Bilt Chipper Shredder
Troy Bilt Chipper/Vac 47282
There is a blockage in the outlet from the fuel tank, there is a filter in the tank and it is dirty. Try it anyway. Stephen.
Sep 21, 2009 | Troy-Bilt Chipper Shredder
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Transmission oil change.
"ue only G-L 4 gear oil having a viscosity of SAE 85W-140 or SAE 140"
Apr 21, 2009 | Troy-Bilt Chipper Shredder
5 HP troy bilt chipper sherdder will not rev up under load
Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
Mar 18, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
Troy Bilt Walk Behind Chipper/Shredder/Vacuum 205cc Logo
1,240 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
donald boissonneault
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
