Question about HP Compaq Presario V2000 Notebook
Jumping keyboard I have vista home edition lap top keyboard jumps have had a look in control panel but cant find where i can diable the touch pad as has been suggested can any one hel[ Thanks Marie
  • partizan May 11, 2010
    Can you describe in a bit more detail "keyboard jumps" behaviour? Also what is laptop model?
    President:
  • 2,559 Answers
Click start,control panel,Pen and input devices.
Note:You may need to select classic view in control panel on the left column
Please rate this a fixya
Posted on Feb 08, 2009
How do I stop my tuch pad om my lap top jumping went powerd by inverter
Power is too noisy. Use the battery and switch the laptop off to charge the battery.
Oct 03, 2014 | HP Pavilion Computers & Internet
Cursor jumps while typing in outlook or word or notepad. it behaves in the same manner in the safe mode as well.
try this and see if it works
: In control panel, click on "printers and other hardware" then "mouse" then "pointer options" then uncheck "hide pointer while typing" then "apply" "ok"
Nov 24, 2009 | Microsoft Windows? Vista Home Basic...
Toshiba keyboard problem with window vista enterprise
I have seen this before.
Either you are touching the touchpad with your palms as you type, or the touchpad is set to be very sensitive. Either way, you should reduce the sensitivity of the touchpad. Go into the control panel, and go into the mouse properties. On the hardware tab, you should be able to find advanced properties and the sensitivity adjustment. Move the slider to the left to reduce sensitivity. If you stroke the pad very very gently with your finger, the cursor should not move at all. adjust sensitivity until this happens.
Reduce the sensitivity until the cursor stops jumping. This will fix it. :)
Aug 21, 2009 | Computers & Internet
ASUS eee1000HD cursor jumps
Change the sensitivity to the touch pad in the control panel.
If you reduce the sensitivity, it should fix the problem. If not, then the top part of the laptop case needs to be opened and then below the keyboard you need to replace the touch pad.
Aug 09, 2009 | ASUS Eee PC 701 Notebook
Jumping cursor
First, try to adjust the sensitivity for the touchpad in the control panel for the mouse. If this doesn't work you can just plug in an external mouse to disable the touchpad. If it still jumps, read the following.
This will involve opening the top part of the laptop. Usually there is a plastic piece holding down the keyboard. Directly above the keyboard. Use a flat head screwdriver to remove it.
Once you see the keyboard, then remove it. Just below that is the connection to the touchpad, undo it and just tape it to an area underneath the touchpad.
Jul 27, 2009 | ASUS Eee PC 1000H Laptop
Microsoft Mouse cursor jumping around
maybe u can use mousepad, with fabric material
May 28, 2009 | Microsoft Windows XP Home Edition
Moving cursor.
well there is a few things that could possibly be happening. if it is a touch pad or a wireless mouse something like a cell phone sitting close enough to them could be causing some interference. the second one is that you could possibly have the mouse keys turned on where you can control the mouse with the keyboard.
Apr 29, 2008 | Dell Latitude D800 Notebook
Keyboard Cursor Jumping
I have been having the same problem for some time now with my Acer laptop and windows vista.
What worked for me was changing a Mouse setting in the Control Panel.
Go to Control Panel -> Mouse. Then go to the "Tapping" tab and make sure that the "Tap off when typing" box is Checked
Mar 18, 2008 | Acer 91.63X07.001 Keyboard
Istalling mouseb has turned off touch pad ?
This usually happens so you dont have 2 mice running at once. Unplug the new mouse and your touchpad should come back.
Mar 12, 2008 | Recoton Advent Advent Q2035A 20" TV
Mouse on lap top dosent work
Can you tell me the model of laptop you have? Have you checked the settings in the control panel?
Nov 30, 2007 | KEIO PS2 Optical Scroll Mouse
HP Compaq Presario V2000 Notebook Logo
266 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
