Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Batteries weak My safe will not accept my pin because of the batteries being to weak. The keys were missed placed and need to get inside the safe. Is there anyway I can get enough juice to the keypad to open the cylinders
  • 257 Answers
Hi, Don't know the make and model of your safe but this advice works for sentry safes,if it doesn't help you get back to me with a make and model: If you need to know how to put batteries in, Turn the electronic lock clockwise ( to the right) from the 12 o'clock position to the 2 o'clock position which opens it so you can put in 4 fresh AA batteries replace the assembly by turning it to the left from the 2 o'clock back to the 12 o'clock. enter your combination and check for the green light. Good Luck!
Posted on Feb 08, 2009
Batterys are dead , how do i open it?
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Oct 18, 2012 | Sentry Security Safe with Electronic Lock...
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
Safe won't accept the code and the keys are lost
Without the keys and safe code you will need to call a locksmith. Even then they might be skeptical about opening the safe for you. There should not be any "backdoor" way of opening the safe for security reasons otherwise it defeats the reason for having the safe. I would contact the safe manufacturer for further instructions or you will need to cut open the safe if the locksmith and manufacturer cannot help you.
Sep 23, 2009 | Locks & Locksmithing
Need to reset electronic safe
i have changed batteries and pressed the reset button but it still wont open any ideas thanks karen
Jul 22, 2009 | Kitchen Appliances - Others
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
Sentry safe S3877 have key and know combination but battery dead
Apr 08, 2009 | Sentry Fireproof Safe
Electronic digital safe richmond
after six years of good service the batters ran out when we were not at home sadly after all this time I cant find the security key to open my safe the number of it is ho 155 how can I get a new key
Apr 07, 2009 | Safe International Digital Electronic Safe...
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
Dec 19, 2008 | Check Point Network Adapter
Changing the code on standleford es20 safe
If the problem is that the safe is not accepting your pin code, try first code 159A, or 159B that are default codes to open the safe.
If you have the sentry key, open with key, and there is a red button inside the door to reset the code.
If you have no key and default code does not work, call sandleford number at 03 97750699 they will guide in opening the safe.
Nov 07, 2008 | O2 Xda Atom Exec Smartphone
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
631 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
