Question about Gateway Solo 5300 Notebook
I have audio no video from dvd.
I have down loaded sonic cineplayer. Am trying to find driver and see if that is the problem. DVD player is teac dv-28e.
  • 4 Answers
Just doenload KLM Player and run any type of video u want or only for dvd u can download power dvd 7.0.....i am sure they both gona work
Posted on Feb 08, 2009
Teac n533 12v LED/TCD DIGITALT/V
First; try blowing into the DVD reader, sometimes it is just a hair. also try a DVD cleaner disc. Check if the drive spins up correctly, and "listen". If it's spnning but having trouble reading you will hear a whizzing sound as it tries different speeds.
May 06, 2014 | Teac Audio Players & Recorders
How do i get my dell dimension 3100 to play dvd's and dvd-r's sonic cineplayer doesn't want to do anything for me
Try the Open Source VLC player software (from videolan)
If still no luck, chances are it's your DVD drive (you do know you only get 3 changes of 'Region Code' before it locks up ?)
Nov 11, 2012 | Dell Dimension 3100 PC Desktop
Problem loading sonic cineplayer 1.5 from disc
Don't use the auto download system. Go into My Computer and access file download directly on F Drive. This eliminated problem. J
Jan 28, 2009 | Sonic CinePlayer 1.5 for PC
Can't burn data
if it is burning audio and video format it mean the burning is all right, u must choose some other application for burn data cd, like nero burning rom or alcohol etc.
Dec 22, 2008 | Teac (DW-224E) DVD Drive
Troule burning DVD
try these:
Resolution:
1. Delete upper and lower filters. (HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E967-E325-11CE-BFC1-08002BE10318})
2. Uninstall Driver in device manager, restart.
If device is still no shown try the following:
1. Download the pxengine patch (http://patches.sonic.com/PX/pxengine1_08_34a.exe)
2. Install and then restart system.
*The pxengine patch adds to the list of drives supported by the Px Engine (Sonic Record Engine).
Jun 23, 2008 | Sonic Computers & Internet
Wont play dvd movies
have you installed the appropriate codecs ? if not do a search for them from google and install them should cure the problem
cheers
Jan 23, 2008 | Sony DW-U14A 4x DVD-/+R(RW) (ELU14A)...
AUDIO
Your post "...GET AUDIO FROM...PROJECTOR AUDIO OUT ...TO THE AUDIO IN...TEAC DVD..."
The normal answer is yes.
However in your particular case, even if you do it that way, there will be no sound getting into the Teac DVD setup since standard 4 pin S-cable carry only video signals (luminance & chrominance) and no audio component/signal. If you run an RCA cable pair from the cable box's audio out aside from the S cable to the inputs of your projector, then it will work.
An exception would be an 8 pin mini-DIN that looks like an S cable which carries also audio signals.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 31, 2007 | Office Equipment & Supplies
Toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
Nov 12, 2007 | Sony VAIO GRZ660 Notebook
Teac dvd player
how old is your machine? if old enough isuggest you change the lens and try if it can load faster than before
Aug 01, 2007 | Teac DV-3500 DVD Player
Computers & Internet Logo
172 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
