I have tried to clean the print head, align the print head, and deep clean, but my printer wont print magenta, any other ideas? I have tried to clean the print head, align the print head, and deep clean, but my printer wont print magenta, any other ideas?
AnonymousMar 30, 2009
same problem- mine's magenta. was working fine, then all of sudden, with no warning or degradation of any kind, just stopped printing magenta. same problem- mine's magenta. was working fine, then all of sudden, with no warning or degradation of any kind, just stopped printing magenta.
You can't post conmments that contain an email address.
I would suspect your inkjets are blocked Black and blue =purple so the other colors are blocked up Use the nozzle cleaning function to try and remove the clog Run nozzle check after cleaning mode till all colors print correctly
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color. Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Occasionally printer cartirdges can clog and become unusable after refilling them several times. Also, if a printer cartridge has been "dry" for a long period it may experience the same problem. Your best bet is to buy replacement cartridges for any colours that show problems on the test page. If there is a blue & green hue to your printing that would suggest that the magenta is not printing and should be replaced.
Call Epson tech support and then Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month. http://www.inkproducts.com/ink-store/
