Question about LG WD-12124RD Front Load Washer
LG FRont Load Washer Dryer WD-1256RD filling up with lint
The front rubber door seal of the loader fills with lint and blocks the door seal drain hole.
The lint build up behind the rubber all the way around.
How do you fix this?
Has anyone else had the same problem?
My Magtag top loading washing machine has a sluggish spin and does not completely remove the water.
Posted on May 15, 2010
  • LG Master
  • 19,396 Answers
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Posted on Feb 08, 2009
LG WD1433RD Washing comes out with black lines and sometimes even worse Have cleaned rubber seal repeatedly Same problem for years every few washes
My LG Front Loader Washing Machine WD-1433RD having a leakage from Front when it fills the water up to ~70% of water. There is no leakage prior to that level. Please help me to fix this.
Feb 19, 2011 | LG WD14311RD Front Load Washer / Dryer
Water not filling machine and do not see suds but it does sound like its filling up. Hear it filling but do not see any water
Not sure of your model but the larger LG front loaders have 2 pumps, 1 for drain and other to pump water up over the clothes through a fitting in the top of the door rubber seal. If something is stuck in the pump or the pump has failed the clothes wont get wet.
Apr 19, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
weak pump...but remember in the drying cycle water is ment to come in and flush out lint and produce air flow for also cools drum..
Dec 16, 2008 | LG WD-14124RD Front Load Washer / Dryer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at no affiliation.
Hall Sensor 6501KW2001A
Here is the Service Manual
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Front load washing machine
There's usually a little drain hole tucked away out of sight at the lowest point of the gusset between the inner and outer seals. Before you try anything else, suggest you check this hasn't got blocked with wet lint (the place I'm trying to describe is the bit that's filling up with manky water). A.
Mar 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
LG WD-12124RD Front Load Washer Logo
572 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
