Question about Sanyo DP37647 37 in. LCD TV
Dark markings or spots on the left side of the lcd screen
These dark markings or spots are wiggly and moving vertical down the left side. it looks like dust or water marking on the inside of the screen.
It is a sanyo dp37647 LCD tv
  • 149 Answers
SOURCE: Sanyo DP37647 32' lcd hdtv
it should you my need the original remote
Posted on Apr 05, 2008
  • 106 Answers
Your TV has panel delaminaion. The lcd panel will need to be replaced. You can contact Samsung and they will point you to an authorized servicer in your area
Posted on Dec 01, 2008
  • 105 Answers
SOURCE: What is the best way to clean the TV screen ?
1Turn off your monitor or set the background color to black so you can easily identify spots that need to be removed. Step2Apply the distilled water to your clean, soft cloth. Step3Wipe your LCD screen in smooth motions from left to right, going from the top of the screen to the bottom. Step4Let the screen air dry or simply run a dry area of the cloth over the screen again.
Posted on Mar 22, 2009
SOURCE: Wanted: 32" Sanyo LCD replacement screen (compatible)
take apart the lcd and find the lcd panel number then email to buy a new panel from a factory in china
then put it all together
Posted on Apr 17, 2009
SOURCE: sanyo lcd tv flat
I have researched this problem and it is so common we that own this piece of junk ought to form a class action suit and sue. It is caused by a bad part or bad connections to a part called a backlight inverter. It seems the LCD needs a higher voltage than supplied by the 12vdc power pack so this part re-chops the DC voltage to generate the LCD requirement.
The date of manufacture is on the back of these TVs and all the problems seem to be from those made in 2006 to 2008
Posted on May 05, 2009
How do I fix the picture?
there is a T con error please replace the T con in this condition
Feb 15, 2016 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Cause of dark spot on 1/4 of & vertical streaked shadows on the rest of screen?
Sounds like panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2015 | Televison & Video
I have a black spot on left side of screen, how can I make it go away?
Dead pixels in the LCD wafer; common issue with LCD televisions as they age. Replace the LCD wafer or consider purchasing a new television.
May 23, 2015 | Coby TFTV3225 32 in. LCD TV
Vizio vertical line
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | Televison & Video
LN-T4971F dark on the right side of screen.
Hey Steve,
Sorry to be the bearer of bad news but you have a bad LCD panel tab. There are videos on youtube that show you how to repair this but they are temporary in nature.
Jun 28, 2013 | Samsung Televison & Video
LG W2261 VP HDMI problem, 1920:1080 doesnt fit right, there is 2cm dark screen at the edge of the display Got drivers installed for analog -vga and digital -hdmi Tried the buttons on monitor...doesnt...
This problem seem to be the LCD screen have dead pixels or a bruise spots on the LCD screen itself that why you have dark spot or spots on the LCD Screen.This problems can't be repair because this problems doesn't causes by the electronic circuit boards.Tried move the monitor as an angles to the right or to the left might help some lessen the dark spot on the LCD screen that all you could do.If this problems is a very dard bruised spot will not help all or if it is dead pixels on the LCD screen itself.
Nov 21, 2012 | Computers & Internet
Screen is exhibiting a dark streak mark running vertically on left side. How do I get rid of unsightly defect?
looks like its damaged. Unfortunatelly all you can do is send it of to get it fixed or replaced.
May 11, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Dark area on Sony LCD screen model KDL-46XBR4
This model of SONY TV uses a Samsung display panel, the problem you have is the panel went bad.
SONY was offering an extended warranty to change the panel free, please call SONY to check it out that if they still offer the free replacement.
Sep 26, 2017 | Sony KDL-46XBR4 46 in. LCD Television
Screen has faint "water mark" looking images on both sides of picture
Then the only possibilitiy at this point is the LCD panel having some kind of defect in it. Since you flipped the picture and no change it is a permanent mark or failure. Check to see if you have any warranty left as this will be an expensive part if needed. They do list a diffusion sheet part number PSHEP0288CEZZ that will probably be the first layer of the screen assembly.
May 09, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Sanyo DP37647 37 in. LCD TV Logo
471 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
