Question about Sony DAV-DX255 System
Listen to my TV through my DX255
I just bought a HD samsung 550 with an audio output, but I can't listen to the tv thorugh my home theater.
  • 2 more comments
  • max_wurgler Feb 08, 2009
    Hi jgwhomeequip, yes I think they are. I have a Red Green Blue cable hooked, plus I now added the red and white cable, from the TV audio output, into the TV input on my home theater.
    that's exactly what I have, I checked again, but the problem is still the same. I have a comcast HD box connected to my tv with an HDMI cable, this works perfect. Maybe I should connect through this box? My tv input is now set to HDMI, and not to regular cable. Could this be a problem
    ok, thank you for your help, I will try to connect it through the cable box.
    Thank you for your help, I connected everything through the Comcast Box, and it works.
    President:
  • 1,902 Answers
Are you sure that your AV cables are hooked up properly on the TV from the reciever?
Posted on Feb 08, 2009
  • 2 more comments
  • Jeremy Reddick
    Jeremy Reddick Feb 08, 2009
    ok you should have 5 cables hooked up to your TV from your reciever
    It should go like this.
    On the TV
    Component is Red white and yellow from bottom up.
    Then
    line out is red and white this is on the TV then on the reciever it should be
    red and white TV audio in
    compent video out is red white and yellow
  • Jeremy Reddick
    Yes that is a big issue, I should have asked you if you had something like that. It should work perfect now
  • Jeremy Reddick
    Also make sure that your reciever is turned to TV
  • Jeremy Reddick
    Sweet congrats, have a good weekend and listen loud
Can I connect my Samsung HD tv directly to a surround sound system that I have just bought
Yes...
They are all standardized interfaces...
You will get the most from your system if you read all the owners support information.
Samsung has their own on board system that can control the volume of both units... and there are audio PROFILES you might enjoy trying out... Some sound better when listening to MUSIC, as opposed to MOVIES... or SPEACH... and are labeled as such...
One of the BETTER SAMSUNG THEATER SOUND UNITS also features an AUX input where we found it convenient to apply the
BLUETOOTH receiver for listening to our FAVORITES on our play lists!!
Pretty cool technology...
Enjoy!!
Aug 09, 2016 | Samsung Audio Players & Recorders
HI Guys. I just upgraded to DirecTV HD-DVR ( I have aHR24-200) installed which is connected via HDMI to my Samsung HD TV. I have a Samsung HT-C550 Digital Home Theater System which is now directly...
You're correct and that is exactly how I always recommend setup (contrary to what the manuals tell you). It makes no sense to me to run any signal through any electronics or interconnections that neither use it nor improve it. Hence, I have NO SOURCE VIDEO going to or through my receiver and NO high end audio going to my TV (which could just as well be a monitor with NO audio capabilities, right)?
Audio electronics should receive the BEST digital audio directly from it's root source.
The TV should receive the BEST video directly from ITS root source.
THAT is why most all high end A/V gear has separate audio and video in/outputs.
If that means you have to make some switching choices when using different sources, oh well. At least you won't have experience potential degradation from multiple hops or have to troubleshoot problems that could be anywhere in that chain.
Jul 16, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Jun 26, 2011 | Panasonic Home Theater System System
The ht-c6600 does not have a headphone jack. I want to listen to games and movies without blowing away the neighbors. How to I connect headphones to this system?
This unit has NO usable audio outputs.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-C6600-Home-Theater-Systems-manual/id/23703dj296/t/2/
A workaround would be to see if the TV has a headphone output. Or route the TV audio to a PC and use the PC's heaphone output.
Apr 18, 2011 | Samsung HT-C6600 Theater System
I just bought a samsung home theater in a box system, model Ht-D5500. And i also have a hd cable box. i was wondering how can i connect my cable box up so that i get audio from the speakers instead of the...
There are two ways of connecting to get cable TV audio from your Home Theater System.
1) If your HD cable box has a digital audio out ( either optical or coaxial ) you can connect this to the Samsung Home Theater Systems digital input. While watching a TV channel scroll through the Samsungs input ( source ) selector till you hear the sound. Remember to mute the TV sound while you are doing this.Most probably it will be the CBL/SAT input or Video AUX.
2) If your HD box does not have digital audio out you can connect the Red & White audio out of the same to your Samsungs Aux or TV or Video audio inputs . Ignore the yellow socket and connect only the Red and White audio inputs.For getting Video through the TV connect the HD box to TV via HDMI cable or connect the Yellow video out to the TV's Yellow video in. I am sure it is already connected .
Mar 21, 2011 | Audio Players & Recorders
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Listen to DTV DVR output on TH-C3
im not familiar with this model. can i assume it is a small home theatre system with limited inputs?
in that case, the best thing to do is to feed all your devices...cable, dvr, dvd, etc....into the tv.(audio and video). then use the audio output of the tv to the input on the receiver. you may have to go into the tv menu and set the audio output to the speakers in the tv to fixed mode for a constant level out to the receiver.
good luck
Dec 08, 2009 | JVC TH-C3 System
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
We have a samsung ht-z515 home theater system and a new samsung ln-t4669f hd tv and I'm trying to hook up the system so we can hear it through the speakers. We are on Verizon Fios and I bought a Fiber...
Make sure the TV is set to output audio to the digital optical port. Then make sure you have selected the proper output mode on the home theatre. Unplug the optical cable from the back of the home theatre and see if the red laser is on (don't shine it in your eyes! :))
Sep 03, 2008 | Televison & Video
Sony DAV-DX255 System Logo
206 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
