Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Westinghouse Dishwasher SB907 does not heat the water
I suspect it is a heating element problem as all other functions/cycles work normally. Just want to know if anyone can explain how to access & change the element.
  • Anonymous Apr 24, 2009
    Exactly the same problem. Everything works except heating.
5 Suggested Answers
  • 40 Answers
SOURCE: Westinghouse SB907 Dishwasher
ON the the control pannel it might show a symbol of a lock. You will need to hold that key or sometime Keys for 3 to 5 seconds to release the control lock.
Posted on Sep 15, 2008
  • 105 Answers
SOURCE: Westinghouse SB907 - Water draining out right after filling up
The drain hose has to have a loop in it. In other words as the drain hose exits the dishwasher, it must go up at least 18 inches before it goes down into the drain. If not, the water will siphon out of the machine.
Posted on Apr 17, 2009
TeepOrange
SOURCE: Westinghouse SB907 Top Draw Clips Replacement
Probably too late for you now :( I found this site.
http://spares.alliedappliance.com.au/
If you happen to have yours fixed, I would love instructions on how to reattach my top drawer to the clips! Can't find an image anywhere and just can't figure it out. sigh.
Posted on Jun 13, 2010
  • 1075 Answers
SOURCE: My Westinghouse dishwasher SB907/915/925 is not heating water.
you dont tell me your problem???????.any way,type in the name of the machine and serial to your internet and it will soon come up or type in [cpc board].adrian,,,,,
Posted on Jul 15, 2010
SOURCE: The dishwasher only washes with
It will be the inline heating element, $55
Posted on Mar 02, 2011
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon
Sep 07, 2011 | Westinghouse Dishwashers
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Hi, My westinghouse dishwasher SB907 goes through the washing cycle but doesn't seem to heat up and use the hot water. I have changed the little switch thing, that costs around $20, so what else cold be...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | Dishwashers
No heatinh - Westinghouse SB925SJ*00 - suspect dual water sensor (Water presence and temperature). Require price and availability. Thanks.
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2010 | Westinghouse Dishwashers
I have had the same problem. I removed the heater element and checked the resistance with my multimeter and got the reading of 26.4Ohms which sees ok. I then removed the printed circuit board and found that a joint on the back had burnt out. I have resoldered this joitn and all seems fine now.
Jul 14, 2010 | Westinghouse 24 in. MDP531 RF...
My Dishwasher (Westinghouse907 series) will not advance past the prewash/rinse cycle. I have cleaned out the filters. I also turned it off for a while and when I turned it back on it worked, but has now...
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 23, 2010 | Westinghouse 24 in. MDP531 RF...
Apr 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
1,161 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
