Question about Linksys Ultra RangePlus Wireless Routr Router
Not internet on the desktop
My wireless connection is fine ,but internet on the desktop is go
  • jclyn_07 May 11, 2010
    Is your desktop wired to the router or it is also wireless??
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 11, 2010
    How does you desktop connects to the router (wired/wireless)?
    Was it working before?
    try rebooting the router. (leave it off for a minute and turn it back on)
    Scholar:
  • 141 Answers
Did you call Linksys Techsupport already? Try this http://technicalsupport.blog.friendster.com
Posted on Feb 15, 2009
N600 error 651. My n600 is hardwired to my desktop. my wireless internet connections work fine. The desktop connects to the router no problem, but will not connect to internet. I used the pc yesterday...
If the wireless connects to the internet then the router is fine. Look at re setting the connection on the PC. You might want to check for an update on the driver for your network interface card first.
Feb 20, 2014 | Computers & Internet
Att 2wire 486 router, why does ethernet light go off when widows boots on, wireless works fine?
Are you connected by a cable to the desktop, if so try another cable.Is your ethernet adapter enabled and working properly on the desktop?
Oct 12, 2012 | Computers & Internet
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
Feb 13, 2009 | D-Link AirPlus DI-524 Wireless Router
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Unable to actually connect to the internet?
Have you tried restarting your router? If not, try unplugging the ac power from the router, wait 30 seconds, and plug it back in. That will usually take care of this problem. If that doesn't work, you can try going into "manage your wireless connections", delete your wireless network from the list, then reconnect to your network.
May 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Computer cannot access the internet
Try to disable wireless card on your desktop. With both the wireless and cat-5 socket enabled, "WITHOUT" the proper bridge settings, they will conflict and not be able to read.
Apr 07, 2008 | Computers & Internet
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Linksys Ultra RangePlus Wireless Routr Router Logo
29 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
