Question about Arris SURFboard SBG900 (49402201900) Modem
Need to change the security of my SBG 900 wireless router
Lost the set up diskette and need to cange the security of my router can you help on this
  • Anonymous Mar 13, 2014
    how do i change channels on an SBG 900 modem
Plug your router in with an ethernet connection and type 192.168.100.1 into your browser address bar. This should load the modem login screen. Unless you have changed the username / password they are admin / motorola. From here you can click on wireless and configure the SSID and security setup.
Posted on Feb 08, 2009
Fttgfgdgfg
Cant log on to the wireless motorola 192.168.0.1
If you got to the router's interface by typing 192.168.0.1 and it requested the userid and password. If the password you enter did not let you in, then the password is wrong. Maybe someone changed the default userid and password to something else.
You can always press the reset button on the router to set it back to Factory Settings. Then the default userid and password will work, but you will have to set the wireless back up and configure the basic settings (if you have a userid and password that the phone company uses as the network userid and password. This is not your email address userid and password).
Jun 07, 2012 | Arris SURFboard SBG900 Wireless Router...
If I don't have the disk to run the set up program for my motorola sbg 900 what can I do to set up my connection as a secure network?
go to this ip
http//:192.168.100.1
Defualt login: (if you did not set one)
user: admin
pass: motorola
and you will get the con-fig for the router
also here is the manual for this router/modem.
MotoModem
May 18, 2011 | Arris SURFboard SBG900 (49402201900) Modem
Hi, i have the Netgear N600 Wireless USB, wich works well on several routers, BUT doesn't want to connect to the MOTOROLA SBG 900 router. It finds the MOTOROLA ROUTER and prompt me to type the WEP...
You mention "the WEP security code of my internet provider, and from this either you mean the WEB of your Router that you provided that the other devices use, or you mean something like the user name and password that you use to log into the ROUTER to set the settings for it. I'd try to help; but, it's not clear what you are really having an issue with. You should be able to check any device that uses that router and get the information needed. But, mostly devices just need to have you put in the password, in this case the same WEP used on other devices, as long as you are using the same protocol in the new device this should work.
The other issue you have is that you list the model of a Netgear Router: WNDR3400100NAS but you call it a USB, which sounds more like a NIC (network interface card). So, there's confusion over what is trying to connect to what. Are you trying to connect a device, or another router to the first router wirelessly. And that's another problem altogether. So I see three issues with your description, could you be a little more succinct?
Jul 03, 2017 | NetGear WNDR3400 N600 Wireless Dual Band...
I can not connect wirelessly
hardwire to your router and see if you can that way. if so log into your router (internet explorer in the address bar type in 192.168.1.1 Username: linksys and Password:admin (unless someone changed the defaults) then go to Wireless Settings tab, then cange the channel. THen go to Wireless Security tab and reset the "WPA password"
Jun 28, 2010 | Linksys Wireless-G WRT54G Router
I have a Motorola SBG 900 router and I need the password for my network to connect my iPod touch
you will need to check the wireless settings of your router.
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for step by step instructions
Apr 09, 2010 | Arris SURFboard SBG900 802.11g/b...
I want to password protect my sbg 1000 . i have never do it before but i have more stuff running thru now
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here
Jan 06, 2010 | Arris SBG1000 Wireless Cable Modem Gateway...
Weak signal thorugh my sbg 900 wireless surfboard gateway
On the Wireless > SECURITY — basic Page check whether the WPA Encryption type is TKIP.
If all of your wireless clients support AES, change the WPA Encryption to AES. This may make a difference for you.
Jan 03, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Cant lock my signal was trying to find a alternative way because i lost the disk??? i have a SBG 900 and any one can get on my internet signal
There's another option to configure the security or encryption using your SBG 900
Connect your computer to one of the LAN ports
Access the configuration of the modem (example 192.168.254.1)
The if you got the configuration page open find the wireless settings and configure the WPA or WEP security using your modem.
Mar 08, 2009 | Arris SURFboard SBG900 Wireless Router...
I cannot connect to my router
resat your router that buton you see in router red buton then set
cange admin passwords
wpa to make sure its secure
Aug 15, 2008 | ParkerVision SIGNALMAX WR1500...
Networking with Motorola SBG 900 Gateway
No, you don't need a router... that gateway supports up to 253 devices on your private network segment. That being said, you only have one ethernet port, so if your desktops have LAN cards rather than wireless, you'll need a hub to split off enough ports. If you add a router, it'll give you a whole new level of complexity. A gateway is a router/modem combo. It converts the Cable Internet signal from your ISP to ethernet and isolates all of the computers behind it into your own private network. A hub is basically an ethernet splitter... it won't isolate a new network segment, it'll just add more ports. Get a hub, they are cheaper and won't add a new level of complexity.
Sep 09, 2007 | Cisco (1841) Router (cisco1841)
Arris SURFboard SBG900 (49402201900) Modem Logo
752 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
