Question about Nikon D80 Digital Camera with 18-135mm Lens
I'm unable to get a full size image on my D80's monitor.
The monitor screen on my D80 will only display a thumbnail view. I've been through the manual and can not find what I must have done wrong. Anyone?
    Scholar:
  • 48 Answers
You must have accidentally hit the Thumbnail button while viewing photos (the one with a magnifying glass and 4-way arrow). Press the Playback Zoom button (bottom one with just the magnifying glass) to go back to single frame view. If you keep pressing the Zoom button it will zoom in further on the image you are viewing, and you can use the arrows to move around in it.
Posted on Feb 09, 2009
Nikon d80 turn off image information from view screen
The up and down arrows on the multi-function button on the back of the camera set the image on the display. With the display on, press the up or down arrow to function through the display settings and the stop on the one you want.
This often happens when you accidentally hit one of the arrow buttons while taking the picture and this changes the display image to the histogram or other display setting.
Apr 14, 2014 | Nikon D80 Digital Camera with 18-135mm...
Exit fhumbnail nikon coolpix
Rotate the zoom control to "T". If you go too far, rotate it the other way. See pages 73 and 74 of the manual: https://support.nikonusa.com/app/answers/detail/a_id/18250
Sep 29, 2013 | Nikon Cameras
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
D80 Monitor does not function as view finder.
To be able to do what you want, your camera would have to have a feature called "live view"....yours does not.
Jul 21, 2010 | Nikon D80 Digital Camera with 18-135mm...
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
How do I adjust my emachine monitor to display a more realistic picture. It is too wide and stretched out.
Check your graphics/desktop settings for the screen resolution - it should be set to the monitor's native resolution, which is 1024x768.
Dec 03, 2009 | E-Machines eMachines Monitor E15T4
LCD viewing monitor has "optimize image" screen on it
Press up/down on the multiselector to cycle through different views of the image.
Feb 11, 2009 | Nikon D80 Digital Camera with 18-135mm...
The Monitor on my Nikon D80 does not show any image when I try to take a picture - The viewfinder is ok and the camera takes a picture ok and displays it for about 4 seconds on the monitor after taking it....
You can switch it off so as not to show the picture after you take one.
You cannot use the monitor to show images as you're taking them. The D80 does not have a Live View capability.
Sep 19, 2008 | Nikon Cameras
1440 x 900 setting for monitor means I can't see my whole desktop on my toshiba laptop...
Not all laptops display adapters will allow the individual settings for a screen and a monitor to take effect correctly.
This happens especially when one is a widescreen and the other is a standard screen.
It seems your settings are taking effect on both screens at once instead of on each screen individually.
I assume you have adjusted te display sizes in your display settings ?
If so, did you adjust each display separately ?
You may also have to see if your display adapter has the most correct drivers. That may help.
Fran
Sep 15, 2008 | Acer AL1916W 19" LCD Monitor
Elongated desktop and software screen images
Many graphic cards enable you to rotate the screen up to 360 degrees. You could try to post this question again under you graphic card model instead of computer screen model as it is your graphic card that is certainly the problem.
Jul 25, 2006 | Microsoft ChiMei CMV938D 19" Widescreen...
Nikon D80 Digital Camera with 18-135mm Lens Logo
70 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
