Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore side by side model # 58582891- Fan will not run until....
Fan will not run until I reset the temperature dial from the T-stat from off to 3/4 coldest temperature range, then it will run again for a day or two and stop, the compressor is very hot. For the fan to run I have to reset the T-stat again.
I had same problem and while cleaning the dirt out, noticed the fan was stuck. unstuck it and has been working well since. Maybe too simple? maybe not.
Posted on Feb 10, 2009
Fridge works intermittently
Some Of These Fridge Freezers If You Open The Door For The Freezer There Is A Switch Between The Fridge And Freezer Door Mine Done The Same And I Had To Replace That Switch It Turns The Fan On When Door Is Closed And Off When Open
Nov 04, 2013 | Refrigerators
I need a wiring diagram for a furnace Nordyne model # E1EH-012HA. the problem is, the fan will not run in heat mode. The fan works in AC mode and when the t-stat is set in manual mode. (fan) I found a...
you need to set either the switch on the back of the tstat to HE NOT HG or in configuration mode you want the "tstat controls the fan" not "equipment controls the fan" or ELECTRIC HEAT NOT GAS HEAT.
Oct 10, 2017 | Heating & Cooling
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My Kenmore side by side is hot around the door frame. How can I reset or rebot it, if possible. Model #10657943700
Getting warm around the door is OK but getting hot around door indicates a restriction of the airflow below your refrigerator. The compressor produces hot Freon that is pumped out the discharge side of compressor. On many refrigerators the gas goes to the yoder Condenser Loop first and then cooled by the condenser fan motor before going to the freezer section as a liquid.
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. In this case rebooting may not change much but unplugging for 10 minutes and then replugging the power is the same as rebooting. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range. If helpful please rate this solution, Thanks Sea Breeze
Jun 14, 2011 | Kenmore Refrigerators
I have a Kenmore 26' Freestanding Dispenser Side-by-side Refrigerator, Model #596.50692000. I opened the freezer door to find melting ice and thawing food. The warmth started at the top of the...
Hi there
Sounds like bad news I'm afraid.
The freezer evaporator fan runs constantly until the freezer is at temperature.
The chiller fan only runs until the fridge is cold.
If the defrost timer is operating correctly it should only go on defrost about every 6 hours
It is more likely to be the temperature controller
You will need toget a new one.
Regards
Gordon
Apr 22, 2011 | Kenmore Refrigerators
2 year old Kenmore side by side refrigerator is too warm
the freezer feeds the refridgerator with cold air,when you open the freezer door,do you hear the fan blowing,if not you need to change the evap fan motor,next take out the second from bottom food bin and touch back wall,if you feel snow or ice you have a defrost problem, you'll have to take off back wall,advance the timer till it clicks into defrost and see if the heater comes on,if so you have a bad timer,if not read out the t-stat and the heater,if there are plug in wires on t-stat unplug them and bypass the t-stat by plugging t-stat wire to heater if heater comes on change t-stat,leave the heater on to help you defrost the ice off of evap coil and use hair dryer to melt ice,hope that helps
Nov 02, 2009 | Kenmore Refrigerators
Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Aug 13, 2009 | Kenmore 56176
Refrigerator is freezing at the bottom and 60 degrees at the top
probably the fan is not running
take the fan housing off and you may find a buildup of ice preventing the fan from running
Nov 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer and fresh food compartment are warm.
The fridge thermostat is faulty and not cutting in at the required temperature. Fridge stats are not easy to test, so the best way is to bypass the stat to see if the compressor starts. To bypass the stat first unplug the appliance and remove the stat housing from inside the fridge compartment, once you have removed the housing you will see the stat inside. Some stats have 2 terminals some have 3, whatever yours has you will need to connect the compressor wire ( Black) to the live wire (Red or White). When you have bypassed the stat plug the appliance back in and switch on, if the fridge starts up and runs ok you will need to purchase a new stat.
Jul 17, 2008 | Kenmore 57072 Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
259 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
