Question about Samsung Televison & Video
STANDBY LIGHT. i have a hitachi 15'' and the standby light is on but dont matter what button i press the picture just wont come on..please help
  • scope eye
    scope eye May 11, 2010
    it needs to be established if problem lies in the psu or in other part of circuit the usual method is to disconnect the switch mode supply from its load & connect a60w bulb across it if it lights up brightly you kno its ok and problem lies in the rest ofcircuit or if not its in the psu
  • 4 Answers
Establish if fault is in smp or in other part of circuit 1 disconnect smp from rest of circuit 2 connect 60 w light ie filament type 3 if bulb lights up brightly fault lies in other part of circuit [for this purpose may be regarded as aload] conversely if it doesnt fault lies switch mode power supply
Posted on Feb 09, 2009
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
55hds69 hitachi plasma
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
May 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
The TV keeps going into standby mode , comes back to proper picture and with-in 15-20 seconds goes back into standby mode. It happens continueously.
May I know if the standby led light at the front panel is blinking, if so please count how many times it will flash to determine the error code? If not follow the steps below.
In standby mode press the button of the remote control in sequence, " Display ", " Channel 5 ", " Vol (-) ", " Power ". Self diagnosis screen will displays. Le me know the result.
Jdvillanueva
Sep 02, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
My 8 year olddell desktop wont come out of standby mode. Even when switched off then turned on again the light flashes like in standby mode. Tried changing cr2032 battery on motherboard as advised by...
Hi elaineblackb ,
Try to do a power cycle and see if that will work.
  1. Turn off your computer and unplug it from the power outlet
  2. While unplug, press and hold the power button for 15 secs.
  3. Try to turn it back on.
Keith
Jun 13, 2011 | Computers & Internet
My playstaion 3 wont funell any picture through the av scart lead or the hdmi lead but it still turns on and is running fine ?
Please try the following steps :
Connect your PS3 up as normal, A/V or HDMI, it does not matter.
Turn the PS3 off into standby mode (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button after you hear the second beep.
Wait for the PS3 display to be reset.
You can use this method when you change from A/V or HDMI, it simply resets the display back to standard definition
Hope this helps
Oct 28, 2010 | Sony Playstation 3 (PS3) Console
HDMI wont be detected by my tv no matter what troubleshoot i do. HELP PLEASE
Ok follow these steps :
Step 1. Turn your PS3 into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button when you hear the second beep.
Step 3. Wait for your Ps3 to start up
This basically resets the video output back to standard definition so you should now be able to setup your video using the PS3 menu.
Hope this helps and thank you for using FixYa
Aug 19, 2010 | Sony PlayStation 3 40GB System
Hitachi Ultravision won't turn on
it is the power board in the tv hase some bad capasators in it but can cost some money to fix if unsher how to do it on your own if you live in central new york i do have my own shop and im cheep but i can not warenty any thing but i can help 315-280-0508 storm electronics ask for corey
Aug 04, 2009 | Hitachi UltraVision 42HDS52 42 in....
Hitachi CP-X990W projector does turn on after being in standby mode Shows orange LED on bottom under label saying Power. The only way I am able to fix it is to pull out the main power for 10-20 seconds put...
have you replaced the lamps if you have there is a sequence of buttons to push in order to reset the lamp Hrs if not you may need to reseat or replace the lamp
Jun 11, 2008 | Hitachi Televison & Video
Remote code
You won't be able to use it for your dvd player unfortunately.
The code for sky is 0145.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful.
Gaz
Jan 14, 2008 | Hitachi CLU-4324UG Remote Control
Televison & Video Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
