Question about RCA P52960 52" Rear Projection Television
RCA P52770EB Rear Projection TV, Comes on with only red screen
TV worked fine and had great clear picture. We moved the picture to a new house (during cold weather in case that makes a difference) and it came on with everything fine for about 10 minutes and then the Blue and Green Tubes went off with only red working. Reset power a couple times and all three would come on for a few minutes and then go back to red only. Now only the Red comes on. When I removed back panel, Blue and Green tubes are barely glowing while Red is bright. Can anyone help with a suggestion? I was told that the Blue and Green Kein Socket boards needed replaced because they looked to be corroded from some small leakage from the tube coolant. Is this a possible problem?
  • 1030 Answers
SOURCE: RCA D52W20 Blue Tube doesn't power on
From your description it does sound if the blue crt has failed. But it can be the crt board or a high voltage issue. intermittantly like that could be a connection problem. is there any hissing ..cracking or smells?
Posted on Dec 17, 2007
  • 1284 Answers
SOURCE: D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Posted on Jun 26, 2008
  • 1030 Answers
SOURCE: RCA HD R56WH78 projection TV, picture just got ascew,
You are haveing form the sounds of it convergence problems. I see this all the time on this set at the shop. FIrst question in customer menu under setup do you have the convergence option if not consult the tips and tricks section under fl231 problem. if you do have this you may have other troubles the convergence is controled by three seprate boards.
Posted on Nov 11, 2008
  • 60 Answers
SOURCE: Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
Posted on Apr 28, 2009
  • 647 Answers
SOURCE: D52W20BYX1 Green problem
If you unplug the Green CRT board (neckboard) do you get the other 2 tubes comming on?
Posted on Sep 19, 2009
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
RCA D52W20 52in Rear Projection TV/ Picture
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rear Projection TV P52770EB
You could have a few problems . If the front display light flashes only it could be you need a new deflection module . Also the HV block may be bad with it . If you have no front display light when you turn it on it could be the above problem or the signal board could be bad . The signal board would cost the most to get repaired due to it costs more. You would need a meter to check certain testing points to confirm which module is bad . Or call around to see who has the cheapest rate on an estimate to check out your tv. deflection board and hv block est $250 to $300. Signal board $300 to $350. Maybe more if you had a service call if you could not take it to a repair shop. Good luck
Feb 29, 2008 | RCA P52926 52" Rear Projection Television
RCA P52920BL (1999)
The fuse fails when the convergence power supply fails,putting a new fuse in the set will let the unit come back on but convergence is not working,check in screens in the menu to see if you have adj. projection t.v.,if the is not in the menu,replace reg ic part number 215530 on the convergence power supply,this board is above the right module mounted on the black plastic.,hope this helps
Feb 28, 2008 | RCA P52920BL 52" Rear Projection...
RCA D52W23 Replacement screen
the screen assembly comes as one unit both screens together. unless you can get an old one online they run about 250 to 350 new
Feb 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
52" RCA Projection TV
This is an indicates what is know as convergence problem...this could also be what is know as deflection problem... have a technician look at it.
Oct 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
2 new problems with my TV after my move
Well it may just be the signal in your area that isn't quite as good. That's just fact. Also, because the signal may be weaker, it may take longer for the TV to fine tune to get the best picture quality, which would explain the slight blurring after turning your TV on.
Sep 07, 2007 | Mitsubishi WS-65807 65" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
93 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
