Question about Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
UNUSEABLE HEATER HEATER IS SPRAYING FUEL, IGNITER COMES ON BUT WON'T STAY ON LONG ENOUGH TO LITE THE FUEL, THEN IT SHUTS DOWN, NO MATTER WHAT POSITION THE THERMOSTAT IS IN, I HAVE CLEANED LINE OUT GOING TO FUEL NOZZLE, & HAVE TRIED ADJUSTING FUEL MIXTURE SCREWS .
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Have you tried adjusting your thermacouple?
  • 56 Answers
This might help, check behind the ignitor for the sensor eye if it is dirty the ignitor will shut off, the set screws are very sensitive be sure they are set properly ( not to much fuel or air )
Posted on Feb 07, 2009
I have reddy pro 170 i plug it in , the fan & igniter comes on for 10 to 15 seconds then shuts off ,blew through fuel line and nozzle still same result, i do see fuel mist coming out nozzle ,i dont k
You must make sure the mist is not to close to the igniter . If it is it wont be misty enough to ignite. And make sure its in the path of the mist. If its new return it to the store.
Feb 07, 2015 | Reddy Heater Pro-Tough Kerosene/Diesel...
I plug my reddy heater in and it comes on then shuts back off. What is the problem?
Try cleaning the flame sensor. Remove the top of the heater. The flame sensor is a black rubber boot close to the fuel nozzle. Pull is out of it's holder and use a soft cloth or cotton swab to reach into the openning and clean the eye. While you have the top off, watch out for the fan and turn the heater on and use a flashlight to look for fuel spraying from the fuel nozzle into the burn and make sure the igniter is working. I don't know which type you have but it may be the spark plug type or a hot surface igniter which should just glow red hot. Let me know what you find.
Jan 02, 2011 | Heating & Cooling
I have a Dyna Glo-pro multi fuel heater. When I turn it on the ingitor starts working and than the fan comes on for a few seconds. Then the system shuts down because it willnot ignite. The tank is full and...
Since it does not ignite, Please check the ignition transformer. This have a secondary voltage of about 20,000 to 25,000 volts, enough to make your igniter
spark, thus, causing the atomized fuel to ignite and burn the fuel. So, please include igniter high voltage cable for ground leak. Ground leak is visible as line sparks when your heater is switched on. If your ignition transformer does not produce sparks at the
igniter, it means it needs to be replaced.
Have it done to make it work. Hope this will help you.
Jan 10, 2010 | Dyna-Glo RMC-8001SS Heater
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Seems that my R-40 is not pumping fuel
You must set the pressure! If the heater runs with your compressor connected, but won't when the pressure is disconnected, well.......
Setting the pressure is easy!
Jan 15, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Runs for 15 secc.'s to 1 Min. Then Shuts off...
Steve- You've got to understandhow it's supposed to work before you can fix it.!
  1. The ignitor only glows for 5 seconds. Just long enough to start combustion.
  2. The photocell monitors the flame color. If it doesn't like the color of the flame (or no flame at all), then it shuts the heater down. Does this sound like what may be happening?
You must troubleshoot the system and decide whether you are having a fuel delivery/mixture problem or an electronics problem.
Read these troubleshooting tips.
Good luck.
Dec 10, 2008 | Reddy Heater-30-55,000 BTU Variable
Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat Logo
269 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
