Question about GE PDS22SIS Bottom Freezer Refrigerator
GE GSS25LGMF Water dispenser-no water
My in the door water dispenser stopped working......I changed the filter, reset filter, purged the lines, checked for frozen water in the reservoir, traced water lines to bottom of the door. i disconnected the line, pressed the switch and water came out. but when i hook it back up and press the switch no water comes out of the dispencer.
  • 1,543 Answers
Order and install a WR49X10173 water tube heater. It may take 24 hours to then thaw, but it has worked for me on numerous refrigerators. Cost for the part will run about $50.
Posted on Feb 08, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Feb 10, 2009
    Please don't rate the solution until you try the solution.
Water won't dispense
Your water line may be frozen through the freezer door. Remove the kickpanel at the bottom and you will see a quick disconnect. remove it and shut the freezer door and call for water. if you have water to that point then you know the line is frozen. Only fix is to replace the door or let the ref thaw for 24 hrs. Hope this helps. MJ
May 30, 2010 | GE CleanSteel GSL25JFTBS
I just changed the easy (pop-out) water filter on my Whirlpool refigerator (located at the bottom of the grille) and when I went to use the water it would not stop running, I had to disconnected the main...
Some of the early models had a sphion ball at the dispenser water tube. When this design worked. it was supposed to sphion water back into the supply line after you stopped calling for water.It's recommended that after you replace the filter and or anytime the water lines are accessed, purge the system. Pull at least 1 gal of water from the dispenser to purge the air. Air in the lines will produce back pressure. This pressure not the same as the regulated line pressure, will continue to push water through to the dispenser and or icemaker. Depending on the model design of the unit, the ice maker may be tricky to purge. Ther are several styles, with the ice bin in the door as trickyest.
Ric
Feb 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I own a GE side-by-side model # GSS25LGMF CC; my water dispenser does not work but the ice maker does. I went as far as disconnecting the tube coupler under the door. I press the dispenser button and...
ive seen this before on this model, what is happening is the water line in the door is freezing and clogging up
the best thing you can doo here is disconnect that tube and try to get it defrosted
i usually suggest to turn the unit off
and open the freezer door let the inside come up to room temp
and drain from the coupler
Oct 17, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Monogram ZFSB26DRSS- water dispenser problem
Disconnect the water line at the water inlet valve on the back and try the dispenser to see if water comes out there and see if you hear the valve work. If the water comes out here then the problem could be the filter. The mesh screen in the water inlet valve could be stopped up. Disconnect the water supply line to see the screen. You may have to remove the cardboard backing to see the valve on the back of the freezer.
Oct 05, 2009 | Refrigerators
No water, no ice, but new water filter cartridge
If it was running before the filter change you need to purge the filter cartridge of the air in the lines. Also check voltage on the back on the water control valves . While someone presses dispenser you should get 120volts AC on the plug receptacle side for the dispenser . Let me know what you find, Sea Breeze
May 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Jan 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Hotpoint s/s fridge. Water dispenser not working. Just changed water filter.
I had to purge the water line about 6 times after changing the filter. And it worked.
Dec 02, 2008 | GE Refrigerators
Water does not dispense from the door but there is water to the filter fitting
connect the water line in to the solenoid [with out the filter] to see if u dispensing water
Dec 01, 2007 | GE Monogram ZISx420DR 42-inch Side by Side...
Open Questions:
GE PDS22SIS Bottom Freezer Refrigerator Logo
436 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
